Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Snappyhexmesh, abberations in mesh
Old   August 29, 2024, 08:46
Default Snappyhexmesh, abberations in mesh
Tale Egeberg Aasland
tale_aasland is on a distinguished road
I'm new with openFoam, and trying to learn snappyhexmesh. Right now, I'm working on a mesh for the bottom of a pontoon, but strange abberations show up when I run snappyhexmesh. These are mostly outside of the refined regions, as shown in the screenshot (I've included a screenshot of the 3D geometry, for reference).
Clearly, I'm doing something wrong in the setup, though I can't figure out what. Any help is much appreciated.
Here's the dict:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 12
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry //stl file, OpenFoam bounding geometry or both
pontoon
type triSurfaceMesh;
file "pontoon.stl";
bigbox
type searchableBox;
min (-30 -15 0);
max (40 15 10);
box
type searchableBox;
min (-27 -9 0);
max (30 9 6);
castellatedMeshControls
maxLocalCells 500000;
maxGlobalCells 5000000;
minRefinementCells 0;
nCellsBetweenLevels 1;
features
file "pontoon.eMesh";
level 3;
refinementSurfaces
pontoon
// Surface-wise min and max refinement level
level (4 4);
refinementRegions
box
mode inside;
level 2;
bigbox
mode inside;
level 1;
resolveFeatureAngle 30;
planarAngle 30;
allowFreeStandingZoneFaces true;
insidePoint (-30 -20 5);
snapControls
nSmoothPatch 3;
tolerance 1;
nSolveIter 100;
nRelaxIter 5;
// Feature snapping
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap true;
meshQualityControls
maxNonOrtho 75;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1.00E-13;
minTetQuality 1e15;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
minFlatness 0.5;
nSmoothScale 4;
errorReduction 0.75;
mergeTolerance 1e-6;
tale_aasland is offline   Reply With Quote
Old   September 5, 2024, 04:37
M
AtoHM is on a distinguished road
Its just a visualization issue. Per default, paraview decomposes the hexahedrons into tetraeder cells. You can see here how to get a representation of the hexahedrons: How to visualize polyhedron mesh in paraview
Furthermore, if you create a slice or clip of the mesh, it can happen that cell layers are cut at weird positions. This leads to the lines you see. You can avoid this in the display options of the filter in the properties, look for a checkbox option saying "crinkle". do Squiggles in snappyHexMesh effect quality
AtoHM is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 13:37
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 20:54
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
