Home > Forums > Special Topics > Mesh Generation & Pre-Processing
GMSH: Nodes does not match with the setTransfiniteSurface
Old   August 5, 2024, 19:20
Default GMSH: Nodes does not match with the setTransfiniteSurface
Eric D'Antona
edan0314 is on a distinguished road
I'm working with it to mesh a rocket nozzle. My teacher who is helping me with my thesis passed me this code, and the following error message is showing:
Exception: Surface 1 cannot be meshed using the transfinite algorithm (non-matching number of nodes on opposite sides 1524 != 1473 or 99 != 99)
Error: Surface 1 cannot be meshed using the transfinite algorithm (non-matching number of nodes on opposite sides 1524 != 1473 or 99 != 99)
I don't have any idea why it is not working, I spent my last 2 weeks in this problem. I'm just beginning to work with gmsh, and with python things get much more abstract. If anyone knows how to solve it, I'll be eternally grateful.
The real GMSH code begins at line 190, before that, it is just the definition of the nozzle geometry, and it is all correct.
import gmsh
import sys
import numpy as np
import matplotlib.pyplot as plt
def neg(lst):
    return [ -i for i in lst ]
def getS(n,r):
    if r!=1:
        s=(r-1)/(r**n-1)
    elif r==1:
        s=1/n
    return s
def getPoints(start,stop,n,r):
    s=getS(n,r)
    x=np.zeros(n+1)
    x[0]=start
    x[1:]=start+(stop-start)*s*np.cumsum(np.array([r**i for i in range(n)]))
    return x
def chamber(Rc,step_count,Lc,progression):
    x = getPoints(0,Lc,step_count,progression)#np.linspace(0,Lc,step_count)
    y = Rc*np.ones(len(x))
    return [x,y]
def chamber_exit_circ(Rc,Rt,Lc,theta_t_i,step_count):
    chamber_e_l = Lc
    angles = np.linspace(90, 90 - theta_t_i, step_count+1)
    Xc = chamber_e_l
    Yc = Rc -1.5*Rt
    x = 1.5*Rt*np.cos(angles*np.pi/180) + Xc
    y = 1.5*Rt*np.sin(angles*np.pi/180) + Yc
    return [x,y]
def throat_inlet(Rt,theta_t_i,step_count,progression):
    throat_i_l = 1.5*Rt*np.sin(theta_t_i*np.pi/180)
    angles = getPoints(270 - theta_t_i, 270, step_count+1,progression)
    Xc = throat_i_l
    Yc = 2.5*Rt;
    return [x,y]
def throat_exit(Rt,theta_N,step_count):
    throat_e_l = 0.382*Rt*np.sin(theta_N*np.pi/180)
    angles = np.linspace(270 , 270 + theta_N ,step_count+1)
    Xc = throat_e_l
    Yc = 1.382*Rt
    x = 0.382*Rt*np.cos(angles*np.pi/180) + Xc
    y = 0.382*Rt*np.sin(angles*np.pi/180) + Yc
    return[x,y]
def bell_curve(Rt,Re,theta_N,theta_e,Ln_ratio,step_count,progression):
    # bezler quadratic curve equation %
    expansion_ratio = (Re/Rt)**2
    Nx = 0.382*Rt*np.cos((theta_N - 90)*np.pi/180)
    Ny = 1.382*Rt + 0.382*Rt*np.sin((theta_N - 90)*np.pi/180)
    Ex = Ln_ratio*( (np.sqrt(expansion_ratio) -1)*Rt + 1.5*Rt*(1/np.cos(15*np.pi/180) -1))/np.tan(15*np.pi/180) # Ln
    Ey = Re
    m1 = np.tan(theta_N*np.pi/180)
    m2 = np.tan(theta_e*np.pi/180)
    C1 = Ny - m1*Nx
    C2 = Ey - m2*Ex
    Qx = (C2 - C1)/(m1-m2)
    Qy = (m1*C2 -m2*C1)/(m1-m2)
    x = np.zeros(step_count+1)
    y = np.zeros(step_count+1)
    i=0
    for t in getPoints(0,1,step_count,progression):#np.linspace(0,1,step_count):
        x[i] = (1-t)**2*Nx + 2*(1-t)*t*Qx + t**2*Ex
        y[i] = (1-t)**2*Ny + 2*(1-t)*t*Qy + t**2*Ey
        i=i+1
    return [x,y]
# Rocket Dimensions
Rc = 71   # [mm]
Rt = 35.5 # [mm]
Re = 275  # [mm]
Lc = 100 # [mm]
Ln_ratio = 0.8; # Ratio of conical nozzle
theta_t_i = 30 # [deg]
theta_N = 30   # [deg]
theta_e = 7    # [deg]
step_count_c_e = 40 #20;
step_count_t_i = 60
step_count_t_e = 60 #40
step_count_r = 100 #80
progression_i=1/1.1
progression_bell=1.01
progression_r=1/1.05
# throat exit section
[x_t_e,y_t_e]=throat_exit(Rt,theta_N,step_count_t_e)
# throat inlet section
deltaN_t_i=x_t_e[1]-x_t_e[0]
delta0_t_i=deltaN_t_i*progression_i-throat_i_l *(progression_i-1)
step_count_t_i=int(np.ceil(np.log(deltaN_t_i/delta0_t_i)/np.log(progression_i)))
[x_t_i,y_t_i]=throat_inlet(Rt,theta_t_i,step_count_t_i,progression_i)
# chamber exit section
[x_c_e,y_c_e]=chamber_exit_circ(Rc,Rt,Lc,theta_t_i,step_count_c_e)
delta0_c_e=x_c_e[1]-x_c_e[0]
# chamber exit to throat inlet line
deltaN_ce_ti=x_t_i[1]-x_t_i[0]
L_c_e_ti=np.abs(np.tan((90 + theta_t_i)*np.pi/180)*(y_c_e[-1]-y_t_i[0]))
delta0_ce_ti=x_c_e[-1]-x_c_e[-2]
progression_ce_ti=(L_c_e_ti-delta0_ce_ti)/(L_c_e_ti-deltaN_ce_ti)
step_count_ce_ti=int(np.ceil(np.log(deltaN_ce_ti/delta0_ce_ti)/np.log(progression_ce_ti)))
y_ce_ti = getPoints(y_c_e[-1],y_t_i[0],step_count_ce_ti,progression_ce_ti)
x_ce_ti = np.tan((90 + theta_t_i)*np.pi/180)*y_ce_ti
# chamber section
step_count_c=int(np.ceil(np.log(Lc*(1/progression_i-1)/delta0_c_e+1)/np.log(1/progression_i)))-1
[x_c,y_c]=chamber(Rc,step_count_c,Lc,progression_i)
delta0_c=Lc*getS(step_count_c,progression_i)
## chamber exit section (translate)
x_c_e = x_c_e + x_c[-1] - x_c_e[0]
#translate chamber exit to throat inlet, throat inlet and throat exit section sections
x_ce_ti = x_ce_ti + x_c_e[-1] - x_ce_ti[0]
x_t_i = x_t_i + x_ce_ti[-1] - x_t_i[0]
x_t_e = x_t_e + x_t_i[-1] - x_t_e[0]
# bell section
delta0_t_e=x_t_e[-1]-x_t_e[-2]
Ln=Ln_ratio*( (np.sqrt(expansion_ratio) -1)*Rt + 1.5*Rt*(1/np.cos(15*np.pi/180) -1))/np.tan(15*np.pi/180)
step_count_nozzle=int(np.ceil(np.log(Ln*(progression_bell-1)/delta0_t_e+1)/np.log(progression_bell)))-1
[x_bell,y_bell]=bell_curve(Rt,Re,theta_N,theta_e,Ln_ratio,step_count_nozzle,progression_bell)
#translate bell section
x_bell = x_bell + x_t_e[-1] - x_bell[0]
gmsh.initialize()
gmsh.model.add("RaoNozzle")
factory=gmsh.model.occ
lc = 1
#pos=np.loadtxt('/Users/jsalazar/matlab/RAO-Bell-Nozzle/nozzleContour.csv',delimiter=',', skiprows=1)
x=np.concatenate((x_c,x_c_e[1:],x_ce_ti[1:],x_t_i[1:],x_t_e[1:],x_bell[1:]))
y=np.concatenate((y_c,y_c_e[1:],y_ce_ti[1:],y_t_i[1:],y_t_e[1:],y_bell[1:]))
pos=np.concatenate((x,y))
pos=pos.reshape((len(x),2),order='F')
npts=len(pos)
erase=[]
for i in range(0,npts-1):
    if np.linalg.norm(pos[i]-pos[i+1])==0:
        erase.append(i)
pos=np.delete(pos,erase,0)
npts=len(pos)
np.savetxt('nozzleContour.csv', pos/1e3,delimiter=',', header='x [m] y [m]')
pAxis=[[]]*npts
pBell=[[]]*npts
lAxis=[[]]*(npts-1)
lBell=[[]]*(npts-1)
lRadial=[[]]*2
for i in range(0,npts):
    pBell[i]=factory.addPoint(pos[i,0],pos[i,1],0,lc)
    pAxis[i]=factory.addPoint(pos[i,0],0,0,lc)
    lBell[i]=factory.addLine(pBell[i],pBell[i+1])
    lAxis[i]=factory.addLine(pAxis[i],pAxis[i+1])
j=0
for i in [0,npts-1]:
    print(i)
    lRadial[j]=factory.addLine(pAxis[i],pBell[i])
    factory.synchronize()
    gmsh.model.mesh.setTransfiniteCurve(lRadial[j], step_count_r, meshType="Progression", coef=progression_r)
    j=j+1
lAxis.reverse()
loop=lBell+neg([lRadial[1]])+neg(lAxis)+[lRadial[0]]
cLoop=[]
cLoop.append(factory.addCurveLoop(loop))
surface=[]
surface.append(factory.addPlaneSurface(cLoop))
gmsh.model.mesh.setRecombine(2, surface[0])
gmsh.model.mesh.setTransfiniteSurface(surface[0],cornerTags=[pAxis[0],pAxis[-1],pBell[0],pBell[-1]])
v=factory.extrude([(2,surface[0])],0,0,1,numElements=[1],recombine=True)
gmsh.model.addPhysicalGroup(2,[surface[0],v[0][1]], name="frontAndBack")
gmsh.model.addPhysicalGroup(2,[v[-1][1]], name="inlet")
gmsh.model.addPhysicalGroup(2,[x[1] for x in v[2:npts+1]], name="wall")
gmsh.model.addPhysicalGroup(2,[v[npts+1][1]], name="outlet")
gmsh.model.addPhysicalGroup(2,[x[1] for x in v[npts+2:2*npts+1]], name="axis")
gmsh.model.addPhysicalGroup(3,[v[1][1]], name="internal")
gmsh.model.mesh.generate(3)
gmsh.write("raoNozzle.msh2")
if '-nopopup' not in sys.argv:
    gmsh.fltk.run()
gmsh.finalize()
edan0314 is offline   Reply With Quote
gmsh, mesh 2d
Adding compute nodes - new nodes faster than existing ones? SLC Hardware 3 November 14, 2019 16:35
[Gmsh] gmsh: how to match nodes from different geometries thomas. OpenFOAM Meshing & Mesh Conversion 0 May 5, 2015 05:49
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
