Boundary Layer mesh over a bump on surface using GMSH |
July 26, 2024, 18:28 |
Rutvik Khedkar
Rep Power: 2 |
Hi all,
I am doing a mesh for a bump on a surface. My initial geometry is a triangular bump on the surface. However when I mesh it I get an odd diagonal streak extending from the bottom corner. Following this I smoothed the initial geometry using a b-spline. Meshing this gives a good mesh however the mesh is not generated along the curve. Running the simulations gives a segmentation fault since the nodes are along the curve but the edges connecting the nodes are outside the geometry. I have tried increasing the number of nodes along the curved regions however this results in the edges intersecting with the corner edges, giving errors with building the mesh. Thank you, RK |
boundary layer mesh, error, gmsh |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
