Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Issue with su2 reading mesh file
Old   November 26, 2023, 06:56
Default Issue with su2 reading mesh file
rishi gnanasegar
rgusr21305 is on a distinguished road
Hey guys,
thanks in advance for any help provided.
Ive been trying to run a simple case through su2 where im analysing the flow over the d8 aircraft, ive modelled the aircraft in openvsp, meshed the model in gmsh and am currently attempting to run it in su2. However su2 is having trouble reading the mesh file and initially outputs this error:
Error in "void CPhysicalGeometry:istributeColoring(const CConfig *, CGeometry *)":
Mismatch between NPOIN and number of points listed in mesh file.
Please check the mesh file for correctness.
------------------------------ Error Exit -------------------------------
through trial and error ive found that this error can be fixed by artificially adding one digit to the "NPOIN" numbe------------------- Geometry Preprocessing ( Zone 0 ) -------------------
Error in "bool CSU2ASCIIMeshReaderFVM::ReadMetadata(const bool, CConfig *)":
Could not find the keyword "NMARK=".
Check the SU2 ASCII file format.r in the mesh file, however a new error occurs when this happens which is:
ive iterated the model in both vsp and gmsh multiple times and keep running into the same error, ive also attached the vsp model, stl and gmsh file below. any help would be greatly appreciated.
I will try and upload the files related to this when I convert them into an approriate format for this thread
rgusr21305 is offline   Reply With Quote
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
