Ben
Rep Power: 0 ![]() |
I am new to gmsh and I recently created a structured mesh for the NACA0012 airfoil (to run in openFoam). However, I seem to have a spot with an abnormality/mixing of meshes near the front of the airfoil. Here's a photo of the mesh issue: Screenshot 2023-10-04 102809.jpg Here is the code for my mesh as well: Include "airfoil0012d.geo"; //+ y = 4; x = 10; n_inlet = 60; n_vert = 90; r_vert = 1; n_af = 50; n_wake = 100; r_wake = 1; //+ Point(135) = {1.005, y, 1, 1.0}; //+ Point(136) = {1.005, -y, 1, 1.0}; //+ Point(137) = {x, -y, 1, 1.0}; //+ Point(138) = {x, y, 1, 1.0}; //+ Point(139) = {x, 0, 1, 1.0}; //+ Point(141) = {0, -y, 1, 1.0}; //+ Point(142) = {0, y, 1, 1.0}; //+ Line(5) = {135, 138}; //+ Line(6) = {138, 139}; //+ Line(7) = {139, 137}; //+ Line(8) = {137, 136}; //+ Line(9) = {136, 141}; //+ Line(10) = {142, 135}; //+ Line(11) = {135, 134}; //+ Line(12) = {134, 136}; //+ Circle(13) = {142, 1, 141}; //+ Line(15) = {139, 134}; //+ Line(16) = {141, 77}; //+ Line(17) = {10, 142}; //+ Transfinite Curve {13, 1} = n_inlet Using Progression 1; //+ Transfinite Curve {17, 11, 6, 7, 12, 16} = n_vert Using Progression r_vert; //+ Transfinite Curve {10, 2, 3, 9} = n_af Using Progression 1; //+ Transfinite Curve {5, 15, 8} = n_wake Using Progression r_wake; //+ Curve Loop(1) = {13, 16, -1, 17}; //+ Plane Surface(1) = {1}; //+ Curve Loop(2) = {17, 10, 11, -2}; //+ Plane Surface(2) = {2}; //+ Curve Loop(3) = {11, -15, -6, -5}; //+ Plane Surface(3) = {3}; //+ Curve Loop(4) = {15, 12, -8, -7}; //+ Plane Surface(4) = {4}; //+ Curve Loop(5) = {3, 12, 9, 16}; //+ Plane Surface(5) = {5}; //+ Transfinite Surface {1}; //+ Transfinite Surface {2}; //+ Transfinite Surface {3}; //+ Transfinite Surface {4}; //+ Transfinite Surface {5}; //+ Recombine Surface {1, 2, 3, 4, 5}; //+ Extrude {0, 0, 1} { Surface{1}; Surface{2}; Surface{3}; Surface{4}; Surface{5}; Layers {1}; Recombine; } //+ Physical Volume("internal", 128) = {1, 2, 3, 4, 5}; //+ Physical Surface("inlet", 129) = {26}; //+ Physical Surface("topAndBottom", 130) = {52, 82, 122, 100}; //+ Physical Surface("outlet", 131) = {78, 104}; //+ Physical Surface("airfoil", 132) = {60, 114, 34}; //+ Physical Surface("frontAndBack", 133) = {39, 61, 83, 105, 127, 1, 2, 5, 4, 3}; airfoil0012d.geo: //+ Point(1) = {0,0,1.0}; //+ Point(2) = {0.0005839,0.0042603,1.0}; //+ Point(3) = {0.0023342,0.0084289,1.0}; //+ Point(4) = {0.0052468,0.0125011,1.0}; //+ Point(5) = {0.0093149,0.0164706,1.0}; //+ Point(6) = {0.0145291,0.02033,1.0}; //+ Point(7) = {0.0208771,0.0240706,1.0}; //+ Point(8) = {0.0283441,0.0276827,1.0}; //+ Point(9) = {0.0369127,0.0311559,1.0}; //+ Point(10) = {0.0465628,0.0344792,1.0}; //+ Point(11) = {0.057272,0.0376414,1.0}; //+ Point(12) = {0.0690152,0.040631,1.0}; //+ Point(13) = {0.0817649,0.0434371,1.0}; //+ Point(14) = {0.0954915,0.0460489,1.0}; //+ Point(15) = {0.1101628,0.0484567,1.0}; //+ Point(16) = {0.1257446,0.0506513,1.0}; //+ Point(17) = {0.1422005,0.0526251,1.0}; //+ Point(18) = {0.1594921,0.0543715,1.0}; //+ Point(19) = {0.1775789,0.0558856,1.0}; //+ Point(20) = {0.1964187,0.057164,1.0}; //+ Point(21) = {0.2159676,0.0582048,1.0}; //+ Point(22) = {0.2361799,0.0590081,1.0}; //+ Point(23) = {0.2570083,0.0595755,1.0}; //+ Point(24) = {0.2784042,0.0599102,1.0}; //+ Point(25) = {0.3003177,0.0600172,1.0}; //+ Point(26) = {0.3226976,0.0599028,1.0}; //+ Point(27) = {0.3454915,0.0595747,1.0}; //+ Point(28) = {0.3686463,0.0590419,1.0}; //+ Point(29) = {0.3921079,0.0583145,1.0}; //+ Point(30) = {0.4158215,0.0574033,1.0}; //+ Point(31) = {0.4397317,0.05632,1.0}; //+ Point(32) = {0.4637826,0.0550769,1.0}; //+ Point(33) = {0.4879181,0.0536866,1.0}; //+ Point(34) = {0.5120819,0.052162,1.0}; //+ Point(35) = {0.5362174,0.0505161,1.0}; //+ Point(36) = {0.5602683,0.0487619,1.0}; //+ Point(37) = {0.5841786,0.0469124,1.0}; //+ Point(38) = {0.6078921,0.0449802,1.0}; //+ Point(39) = {0.6313537,0.0429778,1.0}; //+ Point(40) = {0.6545085,0.0409174,1.0}; //+ Point(41) = {0.6773025,0.0388109,1.0}; //+ Point(42) = {0.6996823,0.03667,1.0}; //+ Point(43) = {0.7215958,0.0345058,1.0}; //+ Point(44) = {0.7429917,0.0323294,1.0}; //+ Point(45) = {0.7638202,0.0301515,1.0}; //+ Point(46) = {0.7840324,0.0279828,1.0}; //+ Point(47) = {0.8035813,0.0258337,1.0}; //+ Point(48) = {0.8224211,0.0237142,1.0}; //+ Point(49) = {0.8405079,0.0216347,1.0}; //+ Point(50) = {0.8577995,0.0196051,1.0}; //+ Point(51) = {0.8742554,0.0176353,1.0}; //+ Point(52) = {0.8898372,0.0157351,1.0}; //+ Point(53) = {0.9045085,0.0139143,1.0}; //+ Point(54) = {0.9182351,0.0121823,1.0}; //+ Point(55) = {0.9309849,0.0105485,1.0}; //+ Point(56) = {0.942728,0.0090217,1.0}; //+ Point(57) = {0.9534372,0.0076108,1.0}; //+ Point(58) = {0.9630873,0.0063238,1.0}; //+ Point(59) = {0.9716559,0.0051685,1.0}; //+ Point(60) = {0.9791229,0.0041519,1.0}; //+ Point(61) = {0.9854709,0.0032804,1.0}; //+ Point(62) = {0.990685,0.0025595,1.0}; //+ Point(63) = {0.9947532,0.0019938,1.0}; //+ Point(64) = {0.9976658,0.001587,1.0}; //+ Point(65) = {0.9994161,0.0013419,1.0}; //+ Point(66) = {1,0.00126,1.0}; //+ Point(68) = {0,0,1.0}; //+ Point(69) = {0.0005839,-0.0042603,1.0}; //+ Point(70) = {0.0023342,-0.0084289,1.0}; //+ Point(71) = {0.0052468,-0.0125011,1.0}; //+ Point(72) = {0.0093149,-0.0164706,1.0}; //+ Point(73) = {0.0145291,-0.02033,1.0}; //+ Point(74) = {0.0208771,-0.0240706,1.0}; //+ Point(75) = {0.0283441,-0.0276827,1.0}; //+ Point(76) = {0.0369127,-0.0311559,1.0}; //+ Point(77) = {0.0465628,-0.0344792,1.0}; //+ Point(78) = {0.057272,-0.0376414,1.0}; //+ Point(79) = {0.0690152,-0.040631,1.0}; //+ Point(80) = {0.0817649,-0.0434371,1.0}; //+ Point(81) = {0.0954915,-0.0460489,1.0}; //+ Point(82) = {0.1101628,-0.0484567,1.0}; //+ Point(83) = {0.1257446,-0.0506513,1.0}; //+ Point(84) = {0.1422005,-0.0526251,1.0}; //+ Point(85) = {0.1594921,-0.0543715,1.0}; //+ Point(86) = {0.1775789,-0.0558856,1.0}; //+ Point(87) = {0.1964187,-0.057164,1.0}; //+ Point(88) = {0.2159676,-0.0582048,1.0}; //+ Point(89) = {0.2361799,-0.0590081,1.0}; //+ Point(90) = {0.2570083,-0.0595755,1.0}; //+ Point(91) = {0.2784042,-0.0599102,1.0}; //+ Point(92) = {0.3003177,-0.0600172,1.0}; //+ Point(93) = {0.3226976,-0.0599028,1.0}; //+ Point(94) = {0.3454915,-0.0595747,1.0}; //+ Point(95) = {0.3686463,-0.0590419,1.0}; //+ Point(96) = {0.3921079,-0.0583145,1.0}; //+ Point(97) = {0.4158215,-0.0574033,1.0}; //+ Point(98) = {0.4397317,-0.05632,1.0}; //+ Point(99) = {0.4637826,-0.0550769,1.0}; //+ Point(100) = {0.4879181,-0.0536866,1.0}; //+ Point(101) = {0.5120819,-0.052162,1.0}; //+ Point(102) = {0.5362174,-0.0505161,1.0}; //+ Point(103) = {0.5602683,-0.0487619,1.0}; //+ Point(104) = {0.5841786,-0.0469124,1.0}; //+ Point(105) = {0.6078921,-0.0449802,1.0}; //+ Point(106) = {0.6313537,-0.0429778,1.0}; //+ Point(107) = {0.6545085,-0.0409174,1.0}; //+ Point(108) = {0.6773025,-0.0388109,1.0}; //+ Point(109) = {0.6996823,-0.03667,1.0}; //+ Point(110) = {0.7215958,-0.0345058,1.0}; //+ Point(111) = {0.7429917,-0.0323294,1.0}; //+ Point(112) = {0.7638202,-0.0301515,1.0}; //+ Point(113) = {0.7840324,-0.0279828,1.0}; //+ Point(114) = {0.8035813,-0.0258337,1.0}; //+ Point(115) = {0.8224211,-0.0237142,1.0}; //+ Point(116) = {0.8405079,-0.0216347,1.0}; //+ Point(117) = {0.8577995,-0.0196051,1.0}; //+ Point(118) = {0.8742554,-0.0176353,1.0}; //+ Point(119) = {0.8898372,-0.0157351,1.0}; //+ Point(120) = {0.9045085,-0.0139143,1.0}; //+ Point(121) = {0.9182351,-0.0121823,1.0}; //+ Point(122) = {0.9309849,-0.0105485,1.0}; //+ Point(123) = {0.942728,-0.0090217,1.0}; //+ Point(124) = {0.9534372,-0.0076108,1.0}; //+ Point(125) = {0.9630873,-0.0063238,1.0}; //+ Point(126) = {0.9716559,-0.0051685,1.0}; //+ Point(127) = {0.9791229,-0.0041519,1.0}; //+ Point(128) = {0.9854709,-0.0032804,1.0}; //+ Point(129) = {0.990685,-0.0025595,1.0}; //+ Point(130) = {0.9947532,-0.0019938,1.0}; //+ Point(131) = {0.9976658,-0.001587,1.0}; //+ Point(132) = {0.9994161,-0.0013419,1.0}; //+ Point(133) = {1,-0.00126,1.0}; //+ Point(134) = {1.005, 0, 1, 1.0}; //+ Line(1) = {10,9,8,7,6,5,4,3,2,1,69,70,69,70,71,72,73,74,75,7 6,77}; Line(2) = {10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,2 6,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42, 43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59 ,60,61,62,63,64,65,66,134}; Line(3) = {77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,9 3,94,95,96,97,98,99,100,101,102,103,104,105,106,10 7,108,109,110,111,112,113,114,115,116,117,118,119, 120,121,122,123,124,125,126,127,128,129,130,131,13 2,133,134}; |
Gaurav Gupta
Rep Power: 2 ![]() |
Hii,
I suppose the number of divisions on the leading edge part is not equal to the number of divisions in c inlet (guessing from the photograph). If you use transfinite on the leading edge and make the no. of divisions equal, then the problem will be solved. Regards, Gaurav |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[Gmsh] gmsh meshing problem | CHAYANIT | OpenFOAM Meshing & Mesh Conversion | 0 | September 5, 2018 08:08 |
[Gmsh] Tutorials on basic Gmsh meshing for OpenFOAM | lordvon | OpenFOAM Meshing & Mesh Conversion | 2 | May 16, 2015 10:30 |
[Gmsh] Meshing thin, curved solids in Gmsh | tibich72 | OpenFOAM Meshing & Mesh Conversion | 0 | January 5, 2012 11:05 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
