March 13, 2023, 15:03 |
Reduce number of cells heat exchanger
Pierre LECHEVALIER
Rep Power: 3 |
Dear All,
I am currently using SolidWorks Flow Simulation to simulate an heat exchanger (air/water). I am facing an issue, indeed the heat exchanger is very big (100 tubes, 23m length each). The flow part is possible to simulate, however, when i try to add the heat exchange the number of cells becomes crazy. Particularly, the number of cells in the solid parts. However, my goal is to focus on the flow part and the influence of temperature on this flow. Thus, the solid conduction parts is not very interesting but i can not reduce the number of cells in the solid, it seems to be fixed and imposed by the mesh generator. Do you have an idea about how can i reduce the number of cells ? Thank you ! Best regards, Pierre |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
