Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Refining Mesh Along Cylinder Outer Surfaces
Old   March 7, 2023, 20:51
Default Refining Mesh Along Cylinder Outer Surfaces
Joel Smith
jbsmith162 is on a distinguished road
Using Ansys Fluent, I am simulating natural convection in a cylinder (d=3.127cm with aspect ratio = 5) and am trying to have a slightly denser mesh around the side wall and a much denser mesh at the top and bottom surfaces while keeping the internal elements larger (set at 2mm) with a goal of approximately 200,000 total elements.
I am able to add inflation and multizone features that extend the length of the temperature boundary layer from the top and bottom (2.09cm) and keep the inside elements at 2mm. The problem comes when I try to reduce the element length at the top or bottom or slightly along the side walls. I've found that face sizing reduces the size of all the elements and the face meshing doesn't do anything.
Are there any suggestion on how I can constrain the element size changes to just the outer surfaces and leave the internal elements at 2mm? I welcome and appreciate any insight/help.
Last edited by jbsmith162; March 7, 2023 at 20:54. Reason: Images did not paste into body of text
jbsmith162 is offline   Reply With Quote
cylinder free convection, meshing 3d, natural convection, refinementsurfaces
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
