Unknown entities are generated while extruding to generate a sphere |
June 7, 2022, 07:25 |
I am trying to generate a sphere with version 4.10.3 Gmsh, and two method are used: 1) to use the 'Sphere' command: SetFactory("OpenCASCADE"); //+ This is to set the background mesh size. //+ Check t10.geo for more information. lc = 0.04; Field[1] = Box; Field[1].VIn = lc / 2; Field[1].VOut = lc / 1; Field[1].XMin = -0.1; Field[1].XMax = 0.1; Field[1].YMin = -0.1; Field[1].YMax = 0.1; Field[1].ZMin = -0.1; Field[1].ZMax = 0.1; Background Field = 1; Sphere(1) = {0, 0, 0, 0.1, -Pi/2, Pi/2, 2*Pi}; //+ Surface Loop(1) = {1}; //+ Volume(1) = {1}; //+ This command makes all surface meshes pointing to the outward. ReorientMesh Volume {1}; 2) to use the 'circle arc' then extrude/rotate SetFactory("OpenCASCADE"); //+ This is to set the background mesh size. //+ Check t10.geo for more information. lc = 0.04; //+ Point(1) = {0, 0, 0, lc}; Point(2) = {0, 0.05, 0, lc}; Point(3) = {0, -0.05, 0, lc}; //+ Circle(1) = {2, 1, 3}; //+ Extrude {{0, 1, 0}, {0, 0, 0}, 2*Pi} { Curve{1}; } Both methods generate two unknown entities (curves) at the ends of circle arc. Could anyone show some clues that how these unknown entities come out and how to eliminate them? Appreciate your feedback Qiyue |
Gmsh: Extruding elements in generated mesh | Adil_Khan | Mesh Generation & Pre-Processing | 0 | April 15, 2020 15:32 |
Vortex Rings Generated from low Re sphere | ABF31330 | FLUENT | 1 | August 10, 2017 12:08 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
Unknown walls generated when import .msh file to fluent. | mdw0821 | FLUENT | 4 | October 16, 2012 14:32 |
Mashing Problem? | ji | CFX | 2 | April 4, 2002 06:03 |
