Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Install Salome Failed with error "No module named '_omnipy'"
Old   March 30, 2022, 10:49
Default Install Salome Failed with error "No module named '_omnipy'"
陈玮
duanwuCHEN is on a distinguished road
I've trying to install SALOME-9.8 on ubuntu 20.04. After the download and extraction, I ran the script 'salome'. But i get the following error:
ERROR:salomeContext:Unexpected error:
Traceback (most recent call last):
  File "/home/$USER/Downloads/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04/SALOME/bin/salome/salomeContext.py", line 279, in _startSalome
    res = getattr(self, command)(options) # run appropriate method
  File "/home/$USER/Downloads/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04/SALOME/bin/salome/salomeContext.py", line 354, in _runAppli
    import setenv
  File "/home/$USER/Downloads/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/setenv.py", line 26, in <module>
    import orbmodule
  File "/home/$USER/Downloads/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/orbmodule.py", line 31, in <module>
    from omniORB import CORBA
  File "/home/$USER/Downloads/SALOME-9.8.0-native-UB20.04-SRC/BINARIES-UB20.04/omniORB/lib/python3.8/site-packages/omniORB/__init__.py", line 44, in <module>
    import _omnipy
ModuleNotFoundError: No module named '_omnipy'
I've also installed anaconda on my pc. I'm not sure if it is related with it.
duanwuCHEN is offline   Reply With Quote
Old   March 3, 2023, 05:18
mikulo is on a distinguished road
i encountered the same problem as well. have you solved it? Thanks.
mikulo is offline   Reply With Quote
Old   March 8, 2023, 03:50
陈玮
Maybe that will help you: https://stackoverflow.com/questions/...e-named-omnipy
openfoam, python, salome
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
"No module named libSU2" in py script shirazbj SU2 Installation 3 February 9, 2013 10:12
install OF2.1.1@Fedora17, error--> bash: module: command not found TaPantaRei OpenFOAM Installation 2 September 16, 2012 12:13
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
