May 31, 2021, 07:39 |
Advice on Gmsh
Keith Sloan
Apologies as not a CFD question but there seems to be a number of people here who understand Gmsh and I am trying to get some advice on Gmsh
I want to create a Mesh but it is not for FEM, what I require is a minimum Mesh, that is if the object being Meshed is a cube, I would like a single 2d Quad mesh for each face. For more complicated rectangular objects then each face made of a minimum number of quad or triangular facets. Obviously if the shapes are not flat or have circular edges then I would like a more regular mesh. Now I am aware that some software simplifies meshes by. a process called decimation, does Gmsh support decimation? what about a more direct approach i.e straight to minimum mesh. Could somebody point me in the right direction, thanks |
gmsh |
Rhino3d to Gmsh interface | banksey255 | Main CFD Forum | 0 | November 20, 2020 17:35 |
[Gmsh] Converting gmsh to OpenFoam | Friendly | OpenFOAM Meshing & Mesh Conversion | 3 | June 26, 2018 06:46 |
[Gmsh] Insatlling gmsh from the source code-issue? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 20 | June 12, 2018 07:39 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
