Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Gmsh - Bounding a Step file for Flow Visualisation
Old   December 15, 2020, 03:30
Default Gmsh - Bounding a Step file for Flow Visualisation
Wesley Brooks
DocTrucker is on a distinguished road
Hi All,
I am working with *.geo files with a view to import a step file (opencascade), create a scaled up bounding box around the file and mesh it for fluid flow visualisation.
I can see the box and CAD on the gmsh gui, but the meshing goes through the Step volume. I tried using a boolean option, but the reference to the external faces was lost, and the mesh control was lost.
Can anyone share a link to a worked example that may help my learning?
Thanks. I will add my geo file when I get to my computer.
DocTrucker is offline   Reply With Quote
Old   December 15, 2020, 04:10
Wesley Brooks
As promised, this is what my *.geo is looking like at the moment:
gridsize = 0.05;
SetFactory("OpenCASCADE");
Geometry.OCCTargetUnit = "M";
v() = ShapeFromFile("CAD/Vehicle.step");
Physical Volume("vehicle") = v();
bbox() = BoundingBox Volume{v()};
xmin = bbox(0);
ymin = bbox(1);
zmin = bbox(2);
xmax = bbox(3);
ymax = bbox(4);
zmax = bbox(5);
dx = xmax - xmin;
dy = ymax - ymin;
dz = zmax - zmin;
cx = (xmax + xmin)/2.0;
cy = (ymax + ymin)/2.0;
cz = (zmax + zmin)/2.0;
g_dx = dx * 1.5;
g_dy = dy * 1.5;
g_dz = dz * 3.0;
g_xmin = cx - (g_dx/2.0);
g_xmax = cx + (g_dx/2.0);
g_ymin = cy - (g_dy/2.0);
g_ymax = cy + (g_dy/2.0);
g_zmin = cz - (g_dz/2.0);
g_zmax = cz + (g_dz/2.0);
next_point_tag = newp;
Point(next_point_tag+0) = {g_xmin, g_ymin, g_zmin, gridsize};
Point(next_point_tag+1) = {g_xmax, g_ymin, g_zmin, gridsize};
Point(next_point_tag+2) = {g_xmax, g_ymax, g_zmin, gridsize};
Point(next_point_tag+3) = {g_xmin, g_ymax, g_zmin, gridsize};
next_curve_tag = newl;
Line(next_curve_tag+0) = {next_point_tag+0, next_point_tag+1};
Line(next_curve_tag+1) = {next_point_tag+1, next_point_tag+2};
Line(next_curve_tag+2) = {next_point_tag+2, next_point_tag+3};
Line(next_curve_tag+3) = {next_point_tag+3, next_point_tag+0};
next_curve_loop_tag = newll;
Line Loop(next_curve_loop_tag+0) = {next_curve_tag+0, next_curve_tag+1, next_curve_tag+2, next_curve_tag+3};
next_suface_tag = news;
Plane Surface(next_suface_tag+0) = next_curve_loop_tag+0;
Transfinite Surface {next_suface_tag+0};
Recombine Surface {next_suface_tag+0};
//+0.000001 Bodge on extrude to get all layers.
surfaceVector[] =
Extrude {0, 0, g_dz+0.00001} {
    Surface{next_suface_tag+0};
    Layers{Round(g_dz/gridsize)};
    Recombine;
Physical Surface("bottom") = {next_suface_tag+0};
Physical Surface("top") = surfaceVector[0];
Physical Surface("back") = surfaceVector[2];
Physical Surface("right") = surfaceVector[3];
Physical Surface("front") = surfaceVector[4];
Physical Surface("left") = surfaceVector[5];
Physical Volume("fluid") = surfaceVector[1];
next_volume_tag = newv;
//BooleanDifference(next_volume_tag) = { Volume{"fluid"}; Delete; }{ Volume{"vehicle"}; Delete; };
//BooleanDifference(next_volume_tag) = { Volume{surfaceVector[1]};}{ Volume{v()};};
BooleanDifference(next_volume_tag) = { Volume{surfaceVector[1]}; Delete; }{ Volume{v()}; Delete; };
 Physical Volume("tunnel") = next_volume_tag;
Edit: Advice on what to do to avoid the 'bodge' would also be appreciated! Without this I get an error after clicking 3D on the gmsh GUI that is a list of points that it can't find. Likely ones that are co-incident with the top of the extrusion.
Edit2: I am now working through the https://wiki.openfoam.com/"3_weeks"_series tutorial series.
Old   November 29, 2021, 11:03
Andrea Michelotti
AndreaMichelotti is on a distinguished road
Hi!
Have you solved the problem? I am facing the same issue simulating a wing.
AndreaMichelotti is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
