Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Mesh: circular 3D cylinder with an obstacle inside
Old   September 9, 2020, 01:20
Default Mesh: circular 3D cylinder with an obstacle inside
Ra Miro
ramrebol is on a distinguished road
Hello.
I read how to create a Blockmesh file in order to create a circular 3D cylinder with an obstacle inside. When I finish it I realized that... the resulting blocks are not hexaedral boxes!!... so, I realized that is not the way to simulate this.
Looks BlockMesh is not appropiate to write the mesh of my mesh, What is the appropriate or suggested way for such a problem?
Now I'm trying to simulate a circular cylinder with an obstacle, but the end goal will be to simulate an artery with a valve inside that stops the blood flow, but I want to go step by step.
ramrebol is offline   Reply With Quote
Old   September 15, 2020, 11:11
Ra Miro
Finally, I used Salome to build the mesh. It is not intuitive, but is very powerful.
fsi simulation, mesh 3d
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies MBttR OpenFOAM Meshing & Mesh Conversion 7 October 14, 2016 04:57
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 09:59
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ANSYS Meshing] Meshing Strategy for inside geometry powpow ANSYS Meshing & Geometry 6 January 16, 2013 05:32
