Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Convert existing gmsh mesh to second order?
Old   May 16, 2020, 22:51
Default Convert existing gmsh mesh to second order?
Harris Snyder
hsnyder is on a distinguished road
Hello everyone,
Quick question about gmsh. Is there a way to take an existing gmsh .msh file, and convert it to second order elements? Specifically, I'm trying to go from 8-point hexahedra (hex8) to 20-point hexahedra (hex20). Ideally, I'd like a command-line solution. I tried this:
gmsh -o output.msh -format msh2 input.msh -order 2 -0
But it doesn't seem to work - I still get hex8 elements in the output. Is there a way to do this, or does the order need to be set when the mesh is first generated?
Thanks
hsnyder is offline   Reply With Quote
Old   May 17, 2020, 01:46
Harris Snyder
Answered my own question - you can do it using a gmsh script (i.e. a .geo file).
Merge "input.msh";
SetOrder 2;
Save "output.msh";
Saving that as "convert.geo", you can then run:
gmsh convert.geo -0
gmsh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
GeometricField -> mesh() Function Tobi OpenFOAM Programming & Development 10 November 19, 2020 12:33
can you tell me best gradient, pressure & momentum order selection in fluent sanjiiv FLUENT 6 February 14, 2020 07:07
A high order curvilinear mesh generation(converting) tool is strongly recommended! hyperman Mesh Generation & Pre-Processing 0 June 22, 2018 09:04
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
