May 8, 2020, 20:09 |
problem using Dilate on gmsh
Alex
I would like to modify the size of the mesh saved on vtk file:
Merge "geometry.vtk"; s0[] = Dilate {{0,0,0}, 0.5} {Duplicata{Surface{1};}}; Surface Loop(1) = {s0}; Volume(1) = {1}; Mesh.CharacteristicLengthExtendFromBoundary = 0; Mesh.CharacteristicLengthMax = 40; The problem is that Dilate does not modify the size of the geometry, this remaining constant. How can I modify the size of the system? Thanks |
gmsh 4.5.4, mesh adaptation |
Problem diverges when exhaust valve opens | swerner0711 | AVL FIRE | 0 | September 21, 2018 08:14 |
[Gmsh] gmsh meshing problem | CHAYANIT | OpenFOAM Meshing & Mesh Conversion | 0 | September 5, 2018 09:08 |
Gmsh problem | liub | Mesh Generation & Pre-Processing | 0 | December 17, 2015 14:26 |
[Gmsh] gmsh problem | djamel | OpenFOAM Meshing & Mesh Conversion | 0 | January 7, 2014 14:02 |
[Gmsh] Ubuntu 12.10 Gmsh installation problem | sudo | OpenFOAM Meshing & Mesh Conversion | 0 | November 7, 2013 13:47 |
