Salome Error Importing .step to Shaper > Geom > Mesh |
May 3, 2020, 00:23 |
Carl Reilly
Rep Power: 16 |
I'm relatively new to Salome. I have been playing with the package and have learnt the basics of Shaper, Geometry and Mes. I want to work out how to import a .step assembly into Shaper, add some additional geometry, create groups in Geometry module and them mesh the assembly with sub-meshes for each part. I have each operation worked out however when i try and generate the mesh from a file imported via shaper i get an error. The Warning message stops me selecting a geomerty to mesh. Warning: Geometry object is not a sub-shape of the shape to mesh If I import a .step assembly directly into Geometry module, partition it to 2 solids, I can create groups of faces before meshing the 2 components. I find that if I import the same .step assembly into Shaper, then export to geometry (Features > Export to Geom), then partition it I don't get 2 solids (as I did when importing directly to Geometry module). If I Explode the geometry imported from Shaper I can get 2 solids (explode > to solid). However, if I then create groups and try and mesh I get the below Warning: Geometry object is not a sub-shape of the shape to mesh. Can some one please explain what the difference is in solids created by a .step assembly imported directly into Geometry and one imported via Shaper? And then how I can solve my issue? |
May 7, 2020, 23:03 |
Carl Reilly
Rep Power: 16 |
I have some of this figured out.
When I create the initial mesh, the geometry selected needs the compound geometry (.i.e the geometry entity containing all the geometry pieces you wish to sub-mesh). Then sub-meshes of the individual solid geometries can be created, as they are children of the compound geometry. I still don't understand why Salome behaves differently if the geometry is imported directly into the Geometry module, or imported to Shaper and then exported to the Geometry module. |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
