October 18, 2018, 07:55 |
Mapped meshing
Vignesh Ravi
Rep Power: 8 |
I have a geometry which I am not able to create mapped meshing (picture attached). I applied a edge sizing on both the right edges which is equal to the number of number of divisions on the left edges. But still I am not able to get a mapped part.
Could anyone help? |
October 24, 2018, 09:43 |
Gwenael H.
Rep Power: 20 |
Hi Vignesh,
Is your left edge defined in one or 2 parts ? If it's a splitted edge you have 3 possibilities: 1) you could either use VT to joint those 2 edges together 2) in Ansys meshing specify corner/side/end point in the mapped face 3) split your surface into 2 sub-surfaces to help the mesher Have fun |
October 25, 2018, 11:26 |
Vignesh Ravi
Rep Power: 8 |
Thank you for your help. I will try it once as you told
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 | Touré | ANSYS Meshing & Geometry | 2 | September 26, 2017 06:41 |
Mapped Meshing Problem | Slimmdree | ANSYS Meshing & Geometry | 0 | June 17, 2013 14:32 |
[ICEM] 2D mapped meshing and blocking | SerSe | ANSYS Meshing & Geometry | 0 | November 29, 2011 12:47 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
