How to generate hexahedron mesh for a two-corrugated design? |
Saiyed Tasnim Md. Fahim
Location: Obninsk Institute for nuclear power engineering
Rep Power: 7 ![]() |
I have been working with a corrugated geometry in Ansys Fluent where hexahedron mesh is required.Using the multizone method, I have been able to generate the mesh for 1 corrugation where I have used default settings; but for two corrugation geometry the following message is shown in the workspace:
"A mesh could not be generated using the current setup" I tried slicing the geometry to solve the problem but it wasn't working at all. How to I solve this issue? |
corrugated surface, hexahedron, meshing 3d, multizone meshing |
[ICEM] How to generate this kind of mesh? | mingersai | ANSYS Meshing & Geometry | 51 | February 16, 2017 07:32 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] How to generate a coarse mesh with snappyHexmesh | laplacian | OpenFOAM Meshing & Mesh Conversion | 0 | June 30, 2011 10:41 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
