Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Plot3D Grid Generation
Old   July 10, 2018, 16:15
Default Plot3D Grid Generation
Tareq Abbood
AeroSeeker is on a distinguished road
Hi All,
I'm looking for a software that could create a mesh and save it in a Plot3D format. I'm currently working on a project that uses a custom code to analyse the flow around an aerofoil, this code requires a multi-block, unformatted, double-precision plot3D file.
I have tried Ansys ICEM v170 but when I output the mesh I get a license error. I'm not sure if Pointwise is open source or not, but I assumed it is not, since I cannot find the download option. I have tried another software called Construct2D which outputs .p3d but the code rejected it.
can you please direct me to a software that could generate Plot3D files? I have tried .x format with the code and it worked but that file was created using a Fortran script that wasn't written by myself.
Thank you in advance.
AeroSeeker is offline   Reply With Quote
Old   August 1, 2018, 17:11
hjabird is on a distinguished road
Hi AeroSeeker,
I've gone down the Construct2D path before. I ended up writing my own program for converting the 2D ascii (if I remember correctly) to 3D double precision binary. If you don't find a better solution, it is available at github.com/hjabird/HBTK as a demo program (Plot3D_converter). It ought to compile under both MSVC and GCC (although you'll need a newer version), and you'll also need cmake. You'll need to set BUILD_DEMO_PROGRAMS to on (cmake -D BUILD_DEMO_PROGRAMS=ON ......) to compile it. The program should show its help at the slightest provocation.
Best wishes, HJAB
hjabird is offline   Reply With Quote
Old   August 7, 2018, 21:15
Tareq Abbood
Originally Posted by hjabird View Post
Hi AeroSeeker,
Best wishes, HJAB
Thank you HJAB for the information, I shall compile it and I hope it works.
Regards, AeroSeeker
Old   August 9, 2018, 01:23
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
use tecplolt to convert other format to plot3d format.
ztdep is offline   Reply With Quote
.p3d, .x format, aerofoil, grid, plot3d
structured grid generation pertup Main CFD Forum 0 November 2, 2004 04:05
structured grid generation problem Mehdi Main CFD Forum 0 July 6, 2004 10:19
Cartesian grid generation method Abu Taleb Main CFD Forum 0 April 8, 2001 13:15
Data Structures for unstructured grid generation Dinesh Godavarty Main CFD Forum 0 December 5, 2000 11:49
grid generation help zhe zhang Main CFD Forum 2 November 12, 1999 23:48
