A high order curvilinear mesh generation(converting) tool is strongly recommended! |
June 22, 2018, 09:04 |
bell
A high order curvilinear mesh generation(converting) tool, which is named 'GRIDer', is strongly recommended:
For high order numerical solver, such as DG, high order curvilinear mesh is necessary. If 1st straight-edge mesh is used for high resolution method, non-physics flow phenomenon would appears. A software named 'GRIDer' is found to convert 1st straight-edge mesh into curved-ede mesh for arbitrary cell type, such as triangle, quad, tet, prism, pyramid. INPUT: CGNS type of 1st straight-edge mesh && IGES CAD geometry model. OUTPUT: GMSH format of curved mesh. you can get it from https://github.com/grider2016/grider |
Software to mesh using high order element with unevenly spaced interpolation node | lzhaok6 | Mesh Generation & Pre-Processing | 4 | August 14, 2016 01:01 |
Visualizing mesh regions with high courant number? | Endel | OpenFOAM | 2 | August 20, 2013 04:57 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 08:12 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
