Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Gmsh 3.0 - Boundary layer 3D mesh
Old   April 14, 2018, 04:50
Default Gmsh 3.0 - Boundary layer 3D mesh
Paul Bertrand
PaulBet is on a distinguished road
Dear all,
I just begin to use Gmsh and I have some problems with the last version. I searched some solutions on forums or in the documentation but I still have some problems :
I am trying to use Gmsh to mesh 3D models by taking into account the boundary layer.
My 3D model is from a .STP file and I tried to use the GUI to generate meshes.
I have no problems to generate 3D meshes which are well exported to OpenFoam.
Now, I want ton add some prisms layers at walls to take into account the boundary layer.
I followed all the information that I've found on forums or documentation but it seems that nothing happens when I use
Mesh -> Define -> Size Fields -> New -> Boundary Layer (with the GUI).
I have no errors in the dialog window below, but I have no changes in the mesh...
I think the reason is that I don't fill the fields with good information, especially about EdgesList and NodesList ??
I try to apply layers of prisms on surfaces (as I have a 3D model...) and I am not sure what is expected in these fields (and what is the format (1, 2, ... ?). I have noticed the values of each surface but I don't know how to input them in the fields...
My questions :
- Is there a good tutorial for Gmsh and is there a method described with tutorials or examples about how to do these kinds of meshing or operations ?
- How can I input the expected informations about faces selected, ... in the Boundary Layer window fields (format, ...) ?
Thank you very much in advance for your help and answers,
Best regards,
Paul
PaulBet is offline   Reply With Quote
Old   April 17, 2018, 05:30
Paul Bertrand
It is not the solution that I hoped but I think it's the right solution (?) :
If someone is interested, I will post a more detailled message but I finally used Engrid with a surface mesh from Gmsh (file .msh).
Engrid is very efficient and allows to create a prismatic boundary layer easily, almost as easily as for commercial software.
I will try to improve the method and I will come back to detail it...
But if someone has other method based on Gmsh, I am still interested...
Old   April 19, 2018, 17:16
Alberto Pizarro
AlbertoPi is on a distinguished road
Hi
Boundary Layer Field only works with 2D grids. You have to use 'extrude' commands for 3D problems.
Regards
AlbertoPi is offline   Reply With Quote
boundary layer mesh, gmsh
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
