February 16, 2018, 17:50 |
How to generate 3D fluid mesh around a ship
Rep Power: 10 |
Dear all,
I've been trying to generate a 3D fluid mesh around the ship. First, I need to subtract the ship hull from the original fluid geometry and then mesh it. Right now, I only have the .stl file of the ship hull with all the internal structures (e.g. stiffeners) inside it. The way I can think of is to strip all the internal structures and generate a solid geometry with the bare hull surface. Then import the geometry into Solidworks. Next, use the Cavity functionality in Solidworks to do the subtraction. However, transforming the ship structure (.stl format) into solid (probably .step format) involves a lot of effort especially for complicated structure. Is there any more straightforward way to do this? For instance, would there be any software that could subtract a solid with a surface body in stl format? |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 16:08 |
How to create solid to fluid interface in Fluent using an ICEM CFD mesh. | ekraft | FLUENT | 1 | June 15, 2017 12:59 |
[ICEM] How to generate this kind of mesh? | mingersai | ANSYS Meshing & Geometry | 51 | February 16, 2017 08:32 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
