January 16, 2018, 11:49 |
2D rectangle in Gmsh -naming physical lines
Ruby Marshall
As part of a simulation I am trying to generate a 2D rectangle in Gmsh with significantly more elements in one direction than the other.
The aim is to use it with Su2. Therefore I want to define which lines are the 'left', 'right', 'upper' and 'lower' to enable my boundary conditions to be applied by the solver. However there is a syntax error for the lines under '//Boundaries' Any suggestion as to how i fix this? Thank you mesh code: //+ Point(1) = {-1, 0.1, 0, 1.0}; //+ Point(2) = {1, 0.1, 0, 1.0}; //+ Point(3) = {1, -0.1, 0, 1.0}; //+ Point(4) = {-1, -0.1, 0, 1.0}; //+ Line(1) = {1, 2}; //+ Line(2) = {2, 3}; //+ Line(3) = {3, 4}; //+ Line(4) = {4, 1}; //+ Line Loop(1) = {1, 2, 3, 4}; //+ Plane Surface(1) = {1}; //+ Transfinite Line {3, 1} = 2000 Using Progression 1; //+ Transfinite Line {4, 2} = 5 Using Progression 1; //+ Transfinite Surface {1}; //+ Recombine Surface {1}; //Boundaries Physical Line (“upper_wall”) = Line(1) ; Physical Line (“lower_wall”) = Line(3) ; Physical Line (“left”) = Line(4) ; Physical Line (“right”) = Line(2) ; Physical Surface (“tube”) (1); |
February 10, 2018, 04:53 |
This should work
//Boundaries Physical Line ("upper_wall") = {1}; Physical Line ("lower_wall") = {3}; Physical Line ("left") = {4}; Physical Line ("right") = {2}; Physical Surface("tube") = {1}; I don't know if it's the web site font but Gmsh doesn't recognize the quotation marks of the geo file you post |
2d mesh, boundaries definition, gmsh, gmsh syntax, su2 mesh |
Gmsh does not ouput SU2 markers from physical surfaces | stewels | SU2 | 4 | May 17, 2023 05:15 |
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups | Nico89 | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 05:40 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
