January 10, 2018, 07:52 |
Premesh CAD quality
Fridrik Magnusson
Rep Power: 9 |
I have made a mesh of a very complex structure, and by using snappyHexMesh.
In the process there was a lot of failed meshes, and wondered if anybody has some kind of measure of the premesh quality of a CAD file? I have an idea to a way of quantify this: This is the length of the smallest line divided by the length of the average line |
January 13, 2018, 12:05 |
Vishnu
Rep Power: 11 |
Hi Fridrik,
When you say a 'failure' I would like to specifically know how ? I have not used snappyHexMesh and wanted to know if there are specific criteria setup to know that a mesh is a good one ? Not sure if this answers your question but qualitatively I feel that the CAD is a good one if it is : a. Connected as per the requirements of the simulation being performed (Based on which the geometry can have 1-sided or even 3+ sided edges) b. Ideally should not have self intersections and coincident faces. The main issue I have faced is that most geometries must be 'connected' as intended. This can be a little difficult when you are preparing a complex geometry prior to meshing. Once you DO do this check, your meshing procedure and subsequent cleanup should be not too difficult. G'Luck ! |
premesh, snappyhexmesh |
[ICEM] Unexplained changes of mesh quality and blocking approach | salumi | ANSYS Meshing & Geometry | 9 | November 23, 2016 05:14 |
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? | Rohith Giridhar | ANSYS Meshing & Geometry | 2 | July 11, 2015 19:04 |
[ICEM] Premesh quality criterion: "Angle" and "Min Angle" | saisanthoshm88 | ANSYS Meshing & Geometry | 3 | February 26, 2014 11:23 |
[ICEM] Hex refinement negative quality afterwards | Anorky | ANSYS Meshing & Geometry | 8 | March 22, 2010 04:25 |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 13:23 |
