Home > Forums > Special Topics > Mesh Generation & Pre-Processing
ICEM: Rotating and copying block and geometry issue
Old   November 27, 2017, 18:43
Default ICEM: Rotating and copying block and geometry issue
Abdulaziz Abutunis
ama294 is on a distinguished road
Dear all,
I am simulating wind turbine of 3 blades. I have a problem when I tried to rotate and copy the one-third of the geometry and block: the association of the new blocks' edges is pointing toward the original geometry's curves. However, only a few vertices are misplaced and jumped to the original points.
Thanks in advance
Aziz
ama294 is offline   Reply With Quote
Old   January 11, 2018, 13:47
Federico
eeLio is on a distinguished road
Originally Posted by ama294 View Post
Dear all,
Thanks in advance
Aziz
Dear aziz,
Have you solved your problem?
I have the same problem rotating a 120 deg sector of a horizontal axis tidal turbine
best
eeLio
eeLio is offline   Reply With Quote
Old   January 11, 2018, 15:28
Abdulaziz Abutunis
Dear eeLio,
I went over it by rotating the blocking and geometry but without copying the original (do not select copy). The combination of the rotor parts was done in Fluent, but you need to define the interfaces between the periodic surfaces of rotor parts and also interfaces between outer domain surfaces and the rotor surfaces
Best
Aziz
Old   January 12, 2018, 05:58
Federico
Dear Aziz,
If I well understood you rotated your geometry and blocking in ICEM?
Did you go on Blocking/Transform Blocks/Rotate Blocks or Blocking/Transform Blocks/Copy Periodic Blocking?
I tried without copy the blocking but even just rotating it few edges are distorted describing circular patterns from one sector to the other/s.
best
eelio
Old   January 12, 2018, 18:04
Abdulaziz Abutunis
Yes correct in ICEM.
Blocking/Transform Blocks/Rotate Blocks select transform geometry also but do not select copy. Then, define the other parameters (rotation axis, angle and center point) and click apply.
If this does not work then before you rotate you may need to check edges and vertices association (right click edges under blocking and select show association)
Hope this will help
Best
Aziz
icem, rotate and copy problems
