Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Ansys meshing topology
Old   August 25, 2017, 19:15
Default Ansys meshing topology
Douglas Pereira
douglasvasconcellos is on a distinguished road
Hi all,
I'm working with heat transfer between concentric tubes, and I'm not getting the desirable results yet, in my opinion because of problems in the mesh.
I'm working with ANSYS MESHING, and I encountered several problems configuring my mesh with topology between bodies. If anyone knows or has any MESHING topology material between cylinders and can help me please, I'm sending the mesh geometry as it is.
Thank you.
douglasvasconcellos is offline   Reply With Quote
Old   September 6, 2017, 00:56
Default CFD expert
sila
silambarasan7 is on a distinguished road
I can help you
silambarasan7 is offline   Reply With Quote
Old   September 6, 2017, 03:24
Arjun Kalkur
Arjun_kalkur is on a distinguished road
Draw two perpendicular lines, ie a '+' . Edge size every line equally and then use face meshing choosing quadrilateral method. Bias your edges if needed.
Arjun_kalkur is offline   Reply With Quote
Old   September 11, 2017, 13:19
Douglas Pereira
How could I help? Thank you.
[ANSYS Meshing] Mixed Order Meshing in ANSYS Meshing oozcan ANSYS Meshing & Geometry 1 August 1, 2020 07:48
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD Ctunramran ANSYS Meshing & Geometry 1 February 23, 2016 08:06
Ansys airfoil meshing problem Salah87 ANSYS 0 August 13, 2015 03:49
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 09:12
