O-grid Sholud ı make coordinate transformation |
August 24, 2017, 11:22 |
Burak Kaya
Rep Power: 14 |
I have developed codes that can solve compressible&incompressible flows on cartesian grids. So far I have used staggered cartesian grids but using collacated grid should not be a big issue. I have tested my code on lid driven cavity benchmark results and it works. To further develop the abilities of my code, I have generated an O-grid around a symmetric airfoil with algebraic grid technique(As described in Klaus Hoffmann CFD book volume 1 chapter 9). I can change the domain size and element size without an issue. I want to know whether I should transform the O-grid to a rectangular domain to be able to analyse the fluid flow problem with Finite Volume method. Can I modify the Navier stokes equations to work on the O-grid directly? In other words, can I can get a solution in the domain directly without transforming it to a rectangular domain? I'm sending the link for the plot of the O-grid I have generated below: https://postimg.org/image/ue7kz4k7j/ Thank you. Edit: Sorry for the typo in the title 'Should I'. |
August 30, 2017, 01:00 |
yes, you can .
Discretize the N-S equation in a way like on a unstructured grid system. |
Coordinate Transformation Problem | nooredin | Main CFD Forum | 0 | July 14, 2010 02:34 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
how to make grid for "SST" like small Re method? | wayne | CFX | 0 | June 7, 2008 12:09 |
How make a .gtm grid for pre-CFX using ICEM ????? | IGNA | CFX | 2 | January 24, 2007 09:36 |
a way to make lots of money quick and easy no lies | Dob | Main CFD Forum | 0 | October 10, 2006 17:45 |
