[gmsh] How to create a 3D volume mesh using a existing surface mesh?! |
July 20, 2017, 08:12 |
Robert
Rep Power: 12 |
Dear all,
i try to create a 3D volume mesh above a preexisting surface mesh for the later use in an OpenFOAM simulation. I've generate a .stl file containing my topography and used the gmsh "Reclassify 2D" command to create a suitable .msh file. I merge this new .msh file in gmsh and create the outline of my domain above this mesh. To do this i use the following code: Code:
Mesh.RemeshAlgorithm=1; Mesh.CharacteristicLengthFactor=1.00;//0.05; Merge "cube.msh"; //RefineMesh; CreateTopology; lc = 1; // ++++++++++++++++++++++++++++++++++++++++ // +++++++++ Box above topography +++++++++ // ++++++++++++++++++++++++++++++++++++++++ Point(14) = {29, 20, 2, lc}; Point(15) = {29, 24, 2, lc} ; Point(16) = {31, 24, 2, lc} ; Point(17) = {31, 20, 2, lc} ; Line(40) = {7, 17}; Line(41) = {2, 14}; Line(42) = {1, 15}; Line(43) = {5, 16}; Line(44) = {16, 15}; Line(45) = {15, 14}; Line(46) = {14, 17}; Line(47) = {17, 16}; Line(48) = {5, 1}; Line(49) = {2, 1}; Line(50) = {2, 7}; Line(51) = {7, 5}; Line Loop(2) = {45, 46, 47, 44}; Plane Surface(11) = {2}; Line Loop(3) = {46, -40, -50, 41}; Plane Surface(12) = {3}; Line Loop(4) = {47, -43, -51, 40}; Plane Surface(13) = {4}; Line Loop(5) = {44, -42, -48, 43}; Plane Surface(14) = {5}; Line Loop(7) = {42, 45, -41, 49}; Plane Surface(16) = {7}; Physical Surface("Inlet") = {12}; Physical Surface("Outlet") = {14}; Physical Surface("Front") = {13}; Physical Surface("Back") = {16}; Physical Surface("Top") = {11}; Physical Surface("Surface") = {2}; As you can see i'm able to create (physical) surfaces defining my domain above my surface, which itself is defined as a physical surface. Problem: I'm unable to create a meshed representation of what i've got so far. Can anybody suggest a solution for my problem? With kind regards Robert |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Interpolating volume data onto quad surface mesh | N.R. | CFX | 6 | June 7, 2007 08:15 |
