July 6, 2017, 14:41 |
Reducing the number of nodes
I am trying to make a 2D structured mesh for gas turbine blade with resolved viscous layer. However, as I try to reach y+ in the range 0.8-1 because of the aspect ratio I end up having about 1 million nodes. I have rotational periodic boundaries and everything I do on one side of the blade transfers to the other and increases the number eve more. I have read the best practice guidelines on turbomachinery and some other recommendations on the nodes number and it seems i have too many nodes. I checked everything multiple times (boundary conditions and physics) and I cannot seem to find a fault, plus the results from y+=80 seem to be logical and expected. Is there any tip on what should I do/check to reduce the number of nodes? Is it normal that I have so many nodes for a 2D case? Any advice would be greatly appreciated! Thank you! Elena. Last edited by Elena T; July 6, 2017 at 18:14. |
node number, turbine blade, viscous layer |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[ICEM] Dissociate blocks number of nodes | gi12 | ANSYS Meshing & Geometry | 2 | February 23, 2012 22:33 |
