Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Calculating blade metal angle
Old   July 3, 2017, 11:09
Default Calculating blade metal angle
Marc_Re is on a distinguished road
For my bachelor thesis I am working at a flow analysis of a centrifugal compressor. I want to look at the incidence angle, so I will need the blade LE angle. The impeller geometry (3d, so it has a variable LE angle) is given by a Siemens NX model, which I cut off at my hub and shroud contours. I tried to get the angles following this tutorial, but the ImportCAD feature fails extracting profiles from the blade surface. Does anybody know another possibility or program, which can compute the LE metal angles with a *.prt/*.x_t file? The problem is, that I also don't know how I can extract profiles from NX, because the model is based on the surface and not generated using profiles.
The mesh generation and also the simulation will be done with NUMECA software (Autogrid, Fine).
Thank you,
Marc
Marc_Re is offline   Reply With Quote
angle, cad
Anlysing and Calculating the power output from a wind turbine blade mrswordf1sh FLUENT 1 July 13, 2017 02:42
Centrifugal Pump: Blade Lean Angle? shelmak ANSYS Meshing & Geometry 4 August 10, 2016 17:44
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
