Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Generating a curvilinear mesh: how to connect the nodes?
Old   March 3, 2017, 11:40
Default Generating a curvilinear mesh: how to connect the nodes?
ms518 is on a distinguished road
Good afternoon everyone,
I am going to work on the modification of a curvilinear mesh and am blocking on the final step of its creation.
According to what I could read about mesh generation using transfinite interpolation (that the code uses), the curvilinear mesh is built using a parametric space and adapts to the boundary of the real space.
My current understanding is that I will discretise this parametric space with a Cartesian mesh, giving me the nodes in the parametric space. I then find the nodes in the real physical space using the formula of the transfinite interpolation (adapted to the boundary of the real space).
My question is the following: how to connect the nodes in the physical space to actually plot the curvilinear mesh? Each node has to be connected to his neighbour (of the same direction), but what about the shape of this curve?
Thank you for you help
ms518 is offline   Reply With Quote
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[Other] Dynamic Mesh: Morph internal mesh nodes nucat OpenFOAM Meshing & Mesh Conversion 0 September 15, 2014 12:04
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] ICEM incapable of writing ANSYS input mesh with midside nodes ampa ANSYS Meshing & Geometry 0 April 24, 2013 06:23
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
