Home > Forums > Special Topics > Mesh Generation & Pre-Processing
How to split a boundary face?
Old   January 26, 2017, 09:57
Smile How to split a boundary face?
Max
nikitin-pro is on a distinguished road
I have a mesh with predefined boundary faces (from Salome) which I successfully exported to OpenFOAM via UNV.
One of the boundaries is a wall, half of which should be heated and another half should be adiabatic. So I need to split it in two. I can't split face with Salome, because it will mess up the mesh.
So far I found two ways: (1) topoSet / setSet >> SubsetMesh and (2) codedFixedValue.
Which one would be better in this case? Note that I doubt if I can use (2), because I define temperature BC with fixedGradient and not with fixedValue.
nikitin-pro is offline   Reply With Quote
Old   January 27, 2017, 11:03
Max
solution found. never mind
boundary face, fixedgradient, openfoam
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
