python script to create geometry for salome, and then mesh |
January 13, 2017, 13:09 |
Bill Wang
Rep Power: 12 |
Dear All,
I am trying to create the geometry for salome via Python script. The geometry is like in the attachment. I exported the original Python script from salome via dump study and changed the coordinates for the small squares. But when I load the script in salome, there is an error like: Code:
>>> execfile(r"/home/LEPT/ywang/OpenFOAM/ywang-3.0.1/run/salome/UCUCscript.py") Traceback (most recent call last): File "<input>", line 1, in <module> File "/home/LEPT/ywang/OpenFOAM/ywang-3.0.1/run/salome/UCUCscript.py", line 52, in <module> Edge_8 = geompy.MakeEdge(Vertex_8, Edge_5_vertex_2) File "/usr/local/salome/INSTALL/GEOM/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 284, in OpenCallClose res = theFunction(self, *args, **kwargs) File "/usr/local/salome/INSTALL/GEOM/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 4562, in MakeEdge RaiseIfFailed("MakeEdge", self.ShapesOp) File "/usr/local/salome/INSTALL/GEOM/lib/python2.7/site-packages/salome/salome/geom/geomBuilder.py", line 299, in RaiseIfFailed raise RuntimeError, Method_name + " : " + Operation.GetErrorCode() RuntimeError: MakeEdge : The end points are too close Code:
import sys import salome salome.salome_init() theStudy = salome.myStudy import salome_notebook notebook = salome_notebook.NoteBook(theStudy) sys.path.insert( 0, r'/home/LEPT/ywang/OpenFOAM/ywang-3.0.1/run/salome') ### ### GEOM component ### import GEOM from salome.geom import geomBuilder import math import SALOMEDS import numpy as np geompy = geomBuilder.New(theStudy) O = geompy.MakeVertex(0, 0, 0) OX = geompy.MakeVectorDXDYDZ(1, 0, 0) OY = geompy.MakeVectorDXDYDZ(0, 1, 0) OZ = geompy.MakeVectorDXDYDZ(0, 0, 1) Vertex_1 = geompy.MakeVertex(0, 0, 0) Vertex_2 = geompy.MakeVertex(1, 0, 0) Vertex_3 = geompy.MakeVertex(1, 1, 0) Vertex_4 = geompy.MakeVertex(0, 1, 0) Edge_1 = geompy.MakeEdge(Vertex_1, Vertex_2) Edge_2 = geompy.MakeEdge(Vertex_2, Vertex_3) Edge_3 = geompy.MakeEdge(Vertex_3, Vertex_4) Edge_1_vertex_2 = geompy.GetSubShape(Edge_1, [2]) Edge_4 = geompy.MakeEdge(Vertex_4, Edge_1_vertex_2) Vertex_5 = geompy.MakeVertex(19.138425, 21.870465, 0) Vertex_6 = geompy.MakeVertex(29.745015, 21.870465, 0) Vertex_7 = geompy.MakeVertex(29.745015, 32.477055, 0) Vertex_8 = geompy.MakeVertex(19.138425, 21.870465, 0) Edge_5 = geompy.MakeEdge(Vertex_5, Vertex_6) Edge_6 = geompy.MakeEdge(Vertex_6, Vertex_7) Edge_7 = geompy.MakeEdge(Vertex_7, Vertex_8) Edge_5_vertex_2 = geompy.GetSubShape(Edge_5, [2]) Edge_8 = geompy.MakeEdge(Vertex_8, Edge_5_vertex_2) Vertex_9 = geompy.MakeVertex(3.051645, 11.103165, 0) Vertex_10 = geompy.MakeVertex(13.658235, 11.103165, 0) Vertex_11 = geompy.MakeVertex(13.658235, 21.709755, 0) Vertex_12 = geompy.MakeVertex(3.051645, 11.103165, 0) Edge_9 = geompy.MakeEdge(Vertex_9, Vertex_10) Edge_10 = geompy.MakeEdge(Vertex_10, Vertex_11) Edge_11 = geompy.MakeEdge(Vertex_11, Vertex_12) Edge_9_vertex_2 = geompy.GetSubShape(Edge_9, [2]) Edge_12 = geompy.MakeEdge(Vertex_12, Edge_9_vertex_2) # Face_1 = geompy.MakeFaceWires([Edge_1, Edge_2, Edge_3, Edge_4, Edge_5, Edge_6, Edge_7, Edge_8], 1) geompy.addToStudy( O, 'O' ) geompy.addToStudy( OX, 'OX' ) geompy.addToStudy( OY, 'OY' ) geompy.addToStudy( OZ, 'OZ' ) geompy.addToStudy( Vertex_1, 'Vertex_1' ) geompy.addToStudy( Vertex_2, 'Vertex_2' ) geompy.addToStudy( Vertex_3, 'Vertex_3' ) geompy.addToStudy( Vertex_4, 'Vertex_4' ) geompy.addToStudy( Vertex_5, 'Vertex_5' ) geompy.addToStudy( Vertex_6, 'Vertex_6' ) geompy.addToStudy( Vertex_7, 'Vertex_7' ) geompy.addToStudy( Vertex_8, 'Vertex_8' ) geompy.addToStudy( Vertex_9, 'Vertex_9' ) geompy.addToStudy( Vertex_10, 'Vertex_10' ) geompy.addToStudy( Vertex_11, 'Vertex_11' ) geompy.addToStudy( Vertex_12, 'Vertex_12' ) geompy.addToStudy( Edge_1, 'Edge_1' ) geompy.addToStudy( Edge_2, 'Edge_2' ) geompy.addToStudy( Edge_3, 'Edge_3' ) geompy.addToStudyInFather( Edge_1, Edge_1_vertex_2, 'Edge_1:vertex_2' ) geompy.addToStudy( Edge_4, 'Edge_4' ) geompy.addToStudy( Edge_5, 'Edge_5' ) geompy.addToStudy( Edge_6, 'Edge_6' ) geompy.addToStudy( Edge_7, 'Edge_7' ) geompy.addToStudyInFather( Edge_5, Edge_5_vertex_2, 'Edge_5:vertex_2' ) geompy.addToStudy( Edge_8, 'Edge_8' ) geompy.addToStudy( Edge_9, 'Edge_9' ) geompy.addToStudy( Edge_10, 'Edge_10' ) geompy.addToStudy( Edge_11, 'Edge_11' ) geompy.addToStudyInFather( Edge_9, Edge_9_vertex_2, 'Edge_9:vertex_2' ) geompy.addToStudy( Edge_12, 'Edge_12' ) #geompy.addToStudy( Face_1, 'Face_1' ) if salome.sg.hasDesktop(): salome.sg.updateObjBrowser(1) Best Regards, Bill |
January 15, 2017, 20:06 |
Nicolas Edh
Rep Power: 18 |
Hi bill,
Could it be because vertex5 and vertex8 have the exact same coordinates? Best regards Nicolas |
January 16, 2017, 06:22 |
rectangle function in Salome
Bill Wang
Rep Power: 12 |
Dear Nicolas,
Yes, you are right. I made a mistake about the vortex coordinates. I changed the coordinates and it works fine now. Thank you. Best Regards, Bill Last edited by 6863523; January 16, 2017 at 11:37. |
January 22, 2017, 05:10 |
draw fine mesh in Salome
Bill Wang
Rep Power: 12 |
Dear,
I want to draw fine mesh of the structure mentioned above. I have used the "traditional" approach (mesh: 3D extrusion, sub-meshes: 2D mesh front face, 2D projection to the back, 1D elements in the third direction). However, if the number of the small squares increases, it is a nightmare to chose the edges in order to apply 1D elements in the third direction. I wonder if you guys could give me some suggestions on how to draw finer mesh for this complex structure. A sample of Salome file is also preferred. Thank you in advance. Best Regards, Bill |
March 18, 2017, 10:00 |
Rep Power: 10 |
I have built meshes with python scripts and ran them in salome. I built 3d geometry with the python script then made the men in the same script. Did u get that far?
I've never used submeshes so I cannot really help with that part. Sent from my SM-G930V using CFD Online Forum mobile app |
