September 20, 2016, 12:38 |
2 way FSI (CFX e Mechanical Transient)
Ugo degli Ubaldi
Rep Power: 10 |
hi to all guys,
I'm trying to run a pair two-way fluid structure. I'm using Transient Mechanical and ANSYS CFX. Unfortunately, after countless attempts I can not get any results. My problem consists in a 2D geometry, formed by a pair of floors channels (fluid domain), separated by two membranes (solid domain), subjected to a periodic output pressure change. Unfortunately, the best result was a partial deformation of 16% (should support the 99% up to a change of topology of the system) of the channel thickness, but already it is possible to see a considerable generation of negative volumes, due to the intersecting of the domains . We report a figure to make the idea. If you try to stretch the size of the channel along the bike, or intensify the maximum pressure value the problem crashes. I tried to change the mesh, the time step, and make the less critical phenomenon possible. Where could I go wrong? In the output of the channels I impose a pressure change, which creates a gradient between the two channels. In impogno input a flow condition imposed. The membranes are bound to interlocking ends, for the rest I have a symmetry condition that should simplify things. Thank you all in advance for your attention |
September 20, 2016, 12:53 |
Ugo degli Ubaldi
Rep Power: 10 |
there are other figure
October 6, 2016, 04:43 |
Ugo degli Ubaldi
Rep Power: 10 |
friends, there is no solution?
FSI Transient Thermal Analysis | Abduri | CFX | 1 | January 1, 2017 22:54 |
Mechanical fails, MAPDL doesn't..FSI | KeganLeckness | Structural Mechanics | 0 | August 17, 2015 16:34 |
Negative Element Volume when doing 2-way FSI between CFX and Transient Structural | lund8619 | CFX | 6 | September 30, 2014 16:50 |
Transient Structural Coupleی CFX transient Pressure | sajad_ENG | Structural Mechanics | 0 | December 7, 2013 14:28 |
FSI : CFX or Fluent? | icemaniac178 | ANSYS | 1 | February 19, 2010 06:33 |
