August 16, 2016, 11:14 |
Gmsh error
Rep Power: 10 |
Deal all,
Does anybody find Gmsh is incapable of generating element over 9th order? The program crashes every time when I try to generate 10th order element. I used different machines and got the same result. Thanks for sharing any related experiences and workarounds! |
finite element method, gmsh, mesh, meshing, pre-processing |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
