Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Software to mesh using high order element with unevenly spaced interpolation node
Old   July 9, 2016, 00:32
Unhappy Software to mesh using high order element with unevenly spaced interpolation node
lzhaok6 is on a distinguished road
I'm looking for a software that would be able to generate 3D mesh using spectral element method. By saying spectral element, I mean the gird points are not evenly distributed when high order interpolation is used (e.g. Gauss-Lobatto points).
Softwares I know (e.g. Abaqus, gmsh, Patran...) only allow evenly spaced interpolation nodes. Abaqus seems to allow users to generate their own element type and do the meshing manually. But the illustration in user manual is not very specific. Patran could insert offset point into an individual element but not for all element. (element type can not be defined)
Any advice would be appreciated!
lzhaok6 is offline   Reply With Quote
Old   August 13, 2016, 19:20
Phil Sakievich
psakievich is on a distinguished road
Typically the Gauss-Lobatto points are incorporated on the internals of the element since they are used as the basis/shape functions. A standard mesh should do and then the internals of each element will have the GL points based on the level of p refinements you are using.
psakievich is offline   Reply With Quote
Old   August 14, 2016, 00:01
Thank you psakievich! That was very helpful.
Old   August 14, 2016, 00:22
Phil Sakievich
My pleasure. Also if you plan to use higher order elements remember they don't need to be as small as your standard FV mesh. The elements can be larger since you are getting more points inside of them and they are higher order. If you mesh with the standard for low order methods the size of the model in memory will blow up quickly.
Old   August 14, 2016, 01:01
Got it. Thanks again for reminding me that!
finite element analysis, finite element method, mesh, software, spectral method
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 11:55
High order interpolation mbuffat OpenFOAM Running, Solving & CFD 0 October 15, 2008 04:47
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
