Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Optimal ratio for O-grid in cylindrical pipe
Old   July 8, 2016, 06:19
Default Optimal ratio for O-grid in cylindrical pipe
Plana is on a distinguished road
I have a pretty straightforward question:
I have to simulate flow inside a simple cylindrical pipe with block-structured grids. I have used a standard O-Grid, and I was wondering if there is an optimal ratio between the size of the central block and the radial size of the external blocks (I mean, from the point of view of the shape of the resulting cells, and their deformation).
Right now I am using a mesh with roughly the same size for both parameters and it works well, but maybe there is a better option.
Thanks in advance
Carlos
Plana is offline   Reply With Quote
Old   July 8, 2016, 17:56
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
this one shouldn't be too bad as a rough guidance, as far as I know there is no "perfect" ratio. Are you able to check for cell quality like skewness and expansion ratio with your code? You may want to apply some smoothing, that would greatly increase the mesh quality.
DarylMusashi is offline   Reply With Quote
cylindrical, ogrid, optimal, pipe
Grid refinement ratio for unstructured mesh oj.bulmer CFX 8 October 31, 2019 13:11
[Other] Problem with Cylindrical Pipe Meshing Shivam Sinha OpenFOAM Meshing & Mesh Conversion 1 November 7, 2014 04:21
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 04:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
