Home > Forums > Special Topics > Mesh Generation & Pre-Processing
GMSH Error: Degenerated Hexahedron in extrusion of volume
Old   June 23, 2016, 05:51
Exclamation GMSH Error: Degenerated Hexahedron in extrusion of volume
Hemaditya Malla
hemaditya is on a distinguished road
Hi guys,
I am quite new to using gmsh. I am currently using gmsh v-2.10.1 . I have been trying to mesh an axisymmetric spherical geometry( shaded portion given in this figure attached SphericalWedge_1000.gif).
In order to create the mesh, I proceeded as follows:
1) Generated the required semi-circular sketch in gmsh.
2) Rotated it by -2.5 degrees.
3) Made the required ruled surfaces and the transfinite lines.
4) Extruded the surfaces by 5 degrees to get the wedge shape.
Now, the problem arises when I try to mesh this geometry. When I click on '3D Mesh' , the mesh is generated but it throws up a lot of same errors:
Error : Degenerated Hexahedron in Extrusion of volume 4.
As a reference I am attaching the .geo (In .txt format ) file named 'AxisymCoarse.txt', which is given at the end of this post. This file contains the details of the dimensions of the geometry and the procedure in which the geometry has been generated.
PS: If I was not clear in any way regarding the query, please ask me as I am new to this forum or please feel free to correct me.
Thanks in advance,
Hemaditya
AxisymCoarse.txt
hemaditya is offline   Reply With Quote
Volume of general hexahedron prak_1989 Main CFD Forum 6 April 16, 2018 21:18
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 11:44
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
[Gmsh] Thin walls (baffles) inside volume with Gmsh styleworker OpenFOAM Meshing & Mesh Conversion 1 November 20, 2012 10:32
