Luis
Rep Power: 13 ![]() |
Hello, comunity. Actually i´m making a finite element mesh with icem cfd. This mesh need to combine shell elements (vaults for example) with volume elements such as walls.
I have generate the volume mesh with the octree algorithm and i need to generate the shell elements of the rest of the parts how can i proceed? ![]() https://mega.nz/#!AJgFlaZS!vZB04UvSq...BecObZl6sN5BHc Attached you can find a screenshot of a part of the total body. I have a volume mesh with the octree aproach and i need sheel elements (consitent with the volume elements) on the dome (green part). Thanks, Luis |
sila
Did you solve it ? No means, let me know your requirement.. Regards, Sila |
icem cfd 13.0, shell mesh, volume meshing |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
