May 9, 2016, 10:54 |
Error in checkMesh
Hi guys, I'm new in this world.
I created in blockMeshDict the geometry of my case of study, I have no problem with blockMesh and the visualization but when I check the mesh with checkMesh I get this error: ... Checking geometry... Overall domain bounding box (-0.08 -0.017 0) (0.607 0.017 0.001) Mesh has 1 geometric (non-empty/wedge) directions (0 1 0) Mesh has 1 solution (non-empty) directions (0 1 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 16000 <<Writing 16160 points on non-aligned edges to set nonAlignedEdges Boundary openness (-6.8718e-18 -9.06727e-17 2.57083e-15) OK. Max cell openness = 2.17281e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 2.11458e-09. Maximum face area = 3.41417e-06. Face area magnitudes OK. Min volume = 2.11458e-12. Max volume = 1.7543e-09. Total volume = 1.55673e-05. Cell volumes OK. Mesh non-orthogonality Max: 36.4088 average: 7.91804 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.59275 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End Could you please me help me with this? Thanks ! |
blockmeshdict, check mesh, mesh |
[Other] How to delete cells in OF based on CheckMesh? | AndTen | OpenFOAM Meshing & Mesh Conversion | 15 | July 27, 2018 06:13 |
checkMesh / mesh errors | andybond13 | OpenFOAM Pre-Processing | 0 | June 10, 2015 13:05 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
[Technical] checkMesh states mesh is OK yet faces are bent pentagons | assert | OpenFOAM Meshing & Mesh Conversion | 1 | March 24, 2014 09:10 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
