Rep Power: 10 ![]() |
Hi everyone!
First time I post a question here, hope it's not a stupid one! I am trying to mesh a 3D geometry imported in STEP format and I would like to control the size of the first cell on the boundary. I found the "Boundary Layer" in the "Size fields" menu so I tried to fill the Edges list and to choose the size with the parameters (hwall_n, ratio, thickness...). But then, nothing happens. I tried to remesh but there is no difference... Obviously I do not use it correctly but I don't understand how I am supposed to use it. So, could anyone tell me how to use "Size field" and/or how to choose the thickness of the first cell? Thank you! (Sorry for the bad English, this is not my mother tongue). EDIT : Here is my .geo file : --------------------------------------------------------------------------------- lc = 1; fflc = 4000; Merge "demie_voile_v2.step"; Transfinite Line { 6, 8} = 191 Using Progression 1; Transfinite Line {12, 19} = 2 Using Progression 1; Transfinite Line {13, 16} = 91 Using Progression 1; Transfinite Line {14, 20} = 90 Using Progression 1; Transfinite Line { 9, 11} = 94 Using Progression 1; Mesh.CharacteristicLengthFactor = lc; Mesh.CharacteristicLengthMax = fflc; Physical Line(0) = {9,11,10,14,20,18,13,16,17,12,19,5,6,8,7}; Physical Surface(1) = {1,2,3,4,5,6,7,8}; Field[4] = BoundaryLayer; Field[4].FacesList = {1,2,3,4,5,6,7,8}; Field[4].hfar = fflc; Field[4].hwall_n = 0.1; Field[4].hwall_t = 0.5; Field[4].thickness = 0.01; Field[4].ratio = 1.1; BoundaryLayer Field = 4; --------------------------------------------------------------------------------- I don't know exactly what values I should use. But now it is simply useless. I can take the Boundary layer part off without any difference. Last edited by Ambroise; March 18, 2016 at 08:09. |
Peter
Rep Power: 11 ![]() |
Have a look at the Gmsh documentation. In this specific case, you've set your desired layer thickness at the wall larger than the desired thickness of your entire boundary layer. Also worth noting, Gmsh 2.12+ doesn't seem to generate boundary layers. I would suggest using version 2.10 or 2.11. Good luck! Kind regards, Peter |
Indeed, version 2.11 do create a boundary layer once I changed the settings as you said!
The mesh is not perfect yet but I have a boundary layer! Thanks for your help! ![]() |
boundary cell, boundary layer, boundary layer thickness, gmsh, mesh 3d |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[Gmsh] Default Faces on Boundary Layer | axel | OpenFOAM Meshing & Mesh Conversion | 8 | February 17, 2011 07:47 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
