Home > Forums > Special Topics > Mesh Generation & Pre-Processing
GMSH mismatch at face boundaries
Old   February 8, 2016, 22:11
Default GMSH mismatch at face boundaries
Bharath
bmukund is on a distinguished road
Hi:
I am trying to use GMSH to generate a surface mesh of a given SAT file. I am doing this through batch processing using the starter code given in GMSH/utils/api-deoms
The SAT file is loaded using OCC functionality built into GMSH software
I then call the surface mesher [ model->mesh(2) ] and then write out an STL file.
When I load the STL file, I see that the meshes across face boundaries are not aligned/matched.
The question is: How can I force GMSH to create a single global mesh coherent /aligned across face boundaries ? Is there a switch for doing so ?
Thanks.
bmukund is offline   Reply With Quote
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 37 November 29, 2024 11:15
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
