February 1, 2016, 10:22 |
hex mesh of cylinder with embedded cuboids
Deutschland
dear all,
i'm looking for a while now for a solution to possibly hex-mesh a cylinder with embedded cuboids that have different mechanical properties than the cylinder matrix. However, up to now I could not find any hex mesh algorithm that is able to mesh such a problem. As the cuboids are more or less randomly orientated inside the cylinder, partitioning does not work. What I have so far are the geometries and structured hex meshes for the cuboids, plus the cylinders surface mesh around. Now I thought I could somehow define the cuboids as holes (with closed surface) in the cylinder geometry and mesh this volume with voids. Also to no success so far. If someone has an idea how to potentially tackle such a problem, I'd be very grateful! |
cylinder mesh, hex mesh, void |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 08:59 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
