Home > Forums > Special Topics > Mesh Generation & Pre-Processing
why the finer the mesh the worse the results?
Old   January 23, 2016, 05:35
Default why the finer the mesh the worse the results?
Ema40 is on a distinguished road
I am simulating a turbine as multiphase flow VOF.
Why using a mesh of 0.01 m the results are very close to the exact solution (error of 1%), and with the mesh of 0.005 m they differer from the exact solution of about 13%? The exact solution has been achieved by experimental tests. This occur for different simulated hydraulic conditions (e.g. flowrates)
Thank you
Regards
Ema40 is offline   Reply With Quote
Old   January 24, 2016, 16:05
Kamaladin Saqar
time is on a distinguished road
Send a message via Yahoo to time Send a message via Skype™ to time
Decreasing size of elements has conditions. One of them is Courat Number. I think mesh of 0.005 m does not satisfy suitable Courant Number of the problem.
time is offline   Reply With Quote
Old   January 25, 2016, 06:49
Thank you.
The Courant number should be close to 1. I have reduced the mesh size, and I used the same time discretization. The courant number with the finer mesh is hence closer to 1 than the coarse mesh, but the coarse mesh gives better result. How is it possible?
Thank you very much
Old   January 25, 2016, 11:51
Kamaladin Saqar
Hi
Well that is a good case to state an mesh sensitivity study!
Old   January 25, 2016, 16:32
Thank you. But the sensitivity analysis works well when the accuracy increases with the reduction in the mesh dimension. I obtain the opposite...
Thank you
Old   February 1, 2016, 07:02
Colinda
colinda1 is on a distinguished road
Possibly there is another element in the simulation set-up that is causing the difference, not the mesh dependency. E.g. the boundary conditions, the turbulence model, etc.
The mesh dependency study is one (important, but not the only) element determining the accuracy of the solution.
colinda1 is offline   Reply With Quote
Old   February 1, 2016, 17:55
Thank you.
I do not know. The case file is always the same, and I import on that case the mesh....Strange. Probably the problem can not be well simulated by VOF for example.
Thanks
Old   March 15, 2016, 10:29
VT
chikko04 is on a distinguished road
did you find out the answer to your question? I am affected by the same issue. If i use a finer mesh with same setup i have results totally differents. I am investigating to find out what cause it, but i am whitout any reasonable answer!
chikko04 is offline   Reply With Quote
Old   March 16, 2016, 06:17
Hi, no answer still.
When the mesh reduces, it may be correct that the result change. Then the result should converge until an asyntotic value, and further mesh refinement should not affect the solution any more. But in my case the results change a lot, decrease, increase, ect...they are not asysntotic!
What about your problem?
Old   March 17, 2016, 06:21
VT
I am studing a turbulent flow with a SEM, if increase Polynomial order (that equivalent to increase mesh) or increase mesh to have a more equispaced mesh, the fluid become laminar, instead to be turbulent, how happen with a coarser mesh. And Re is very high...so it is impossible.
mesh, mesh dimension, mesh independency, turbine, vof
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh dependency - possible that refinement = worse results? crisgc FLUENT 4 November 14, 2012 13:16
bubbleFoam - behavior on finer mesh darai OpenFOAM Running, Solving & CFD 8 November 22, 2011 06:15
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
