August 11, 2015, 19:24 |
Deleting part of a mesh and re-meshing
Rep Power: 11 |
I'm using ICEM to generate an unstructured mesh in a pipe (volume mesh using octree algorithm). If I wanted to shorten the pipe would it be possible to delete the section of the volume and surface mesh that I didn't want then re-mesh a new mesh on the end of the pipe that has been truncated? So re-mesh the end volume elements so that they terminate flush with a new end surface and then create a surface mesh on this surface. Obviously I could shorten the geometry and re-mesh the entire pipe, but if I wanted to keep the original mesh and just shorten it would it be possible to do so? Thanks |
delete mesh, icem, re-meshing, surface mesh |
