Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Translating mesh for node dropping correction in axisymmetric swirl geometry
Old   April 17, 2013, 06:02
Default Translating mesh for node dropping correction in axisymmetric swirl geometry
Joakim M. Johansen
jmjohansen is on a distinguished road
I have constructed a 2D-axisymmetric swirl geometry that, when meshed, contains nodes that drop below the X-axis, although the geometry is only defined at positive Y values. (nodes drop less than 17 orders of magnitude below the X-axis).
The FLUENT manual suggests to translate the mesh - however, you will never be able to place the base on exactly the location of the global axis and thus has to be moved to Y-values above 0.
My question is now - just to be sure. Will this offset to the global axis cause problems with the axisymmetric boundary? The fluent manual clearly states, that for axisymmetric swirled geometries, the axis must coincide with the global X-axis. Will my numerical offset cause fluent to not be able to exchange information across the boundary?
Thank you in advance,
Joakim
jmjohansen is offline   Reply With Quote
axis symmetry, axisymmetric mesh, boundary, translating mesh
[ANSYS Meshing] Scale geometry but mesh size to remain same sangrampp ANSYS Meshing & Geometry 1 February 12, 2016 06:19
[ICEM] Create geometry (iges or step file) from fluent mesh muketa ANSYS Meshing & Geometry 10 August 5, 2015 06:38
[ANSYS Meshing] Meshing Strategy for inside geometry powpow ANSYS Meshing & Geometry 6 January 16, 2013 05:32
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 03:49
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
