Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Meshing problem --> Thermo failure
Old   April 8, 2013, 11:59
Default Meshing problem --> Thermo failure
Eric
erichu is on a distinguished road
Hello everyone,
I am trying to simulate maximum flow inside a tiny pipe using totalPressure = 106325 Pa boundary and fixedPressure=101325 Pa.
Dimensions of pipe is (0.004 m length and 0.003 mm diameter)
Using a very coarse netgen mesh and about 15000 iterations, a fully converged solution is obtained.
However, when refine the mesh, a solution cannot be obtained due to failure in the thermophyical- or the pressure model.
Anyone having ideas why the refined mesh cannot converge. Pictures are attached, 'fine2' is the fine mesh and 'coarse' is the coarse mesh.
Thanks
erichu is offline   Reply With Quote
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 19, 2023 00:49
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 12:27
[GAMBIT] 3D Cooper Meshing failure ritwik ANSYS Meshing & Geometry 0 December 1, 2010 08:04
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
