Help -> Meshing of a Cylinder for Pouseuille Flow |
February 18, 2013, 00:14 |
Pedro Feijóo
Hi Everyone,
I'm new using OpenFoam and I've had some problems generating a mesh for a cylinder in which will pass a flow. I have this code, based on this tutorial http://www.foamcfd.org/Nabla/guides/...Guidese12.html (only the idea, not the vertices or anything else). /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( //Radio Interior Frontal (0.5 0 0) //0 (0.353553 0.353553 0) //1 (0 0.5 0) //2 (-0.353553 0.353553 0) //3 (-0.5 0 0) //4 (-0.353553 -0.353553 0) //5 (0 -0.5 0) //6 (0.353553 -0.353553 0) //7 //Radio Exterior Frontal (1 0 0) //8 (0.707106 0.707106 0) //9 (0 1 0) //10 (-0.707106 0.707106 0) //11 (-1 0 0) //12 (-0.707106 -0.707106 0) //13 (0 -1 0) //14 (0.707106 -0.707106 0) //15 //Radio Interior Posterior (0.5 0 1) //16 (0.353553 0.353553 1) //17 (0 0.5 5) //18 (-0.353553 0.353553 1) //19 (-0.5 0 1) //20 (-0.353553 -0.353553 1) //21 (0 -0.5 1) //22 (0.353553 -0.353553 1) //23 //Radio Exterior Posterior (1 0 1) //24 (0.707106 0.707106 1) //25 (0 1 1) //26 (-0.707106 0.707106 1) //27 (-1 0 1) //28 (-0.707106 -0.707106 1) //29 (0 -1 1) //30 (0.707106 -0.707106 1) //31 ); blocks ( hex (0 1 8 9 16 17 24 25) (10 10 1) simpleGrading (1 1 1) hex (1 2 9 10 17 18 25 26) (10 10 1) simpleGrading (1 1 1) hex (2 3 10 11 18 19 26 27) (10 10 1) simpleGrading (1 1 1) hex (3 4 11 12 19 20 27 28) (10 10 1) simpleGrading (1 1 1) hex (4 5 12 13 20 21 28 29) (10 10 1) simpleGrading (1 1 1) hex (5 6 13 14 21 22 29 30) (10 10 1) simpleGrading (1 1 1) hex (6 7 14 15 22 23 30 31) (10 10 1) simpleGrading (1 1 1) hex (7 0 15 8 23 16 31 24) (10 10 1) simpleGrading (1 1 1) ); edges ( // Circulo Exterior Frontal arc 8 9 (0.923879 0.38268 0) arc 9 10 (0.38268 0.923879 0) arc 10 11 (-0.38268 0.923879 0) arc 11 12 (-0.923879 0.38268 0) arc 12 13 (-0.923879 -0.38268 0) arc 13 14 (-0.38268 -0.923879 0) arc 14 15 (0.38268 -0.923879 0) arc 15 8 (0.923879 -0.38268 0) //Circulo Interior Posterior arc 16 17 (0.46194 0.19134 1) arc 17 18 (0.19134 0.46194 1) arc 18 19 (-0.19134 0.46194 1) arc 19 20 (-0.46194 0.19134 1) arc 20 21 (-0.46194 -0.19134 1) arc 21 22 (-0.19134 -0.46194 1) arc 22 23 (0.19134 -0.46194 1) arc 23 16 (0.46194 -0.19134 1) //Circulo Interior Frontal arc 0 1 (0.46194 0.19134 0) arc 1 2 (0.19134 0.46194 0) arc 2 3 (-0.19134 0.46194 0) arc 3 4 (-0.46194 0.19134 0) arc 4 5 (-0.46194 -0.19134 0) arc 5 6 (-0.19134 -0.46194 0) arc 6 7 (0.19134 -0.46194 0) arc 7 0 (0.46194 -0.19134 0) //Circulo Exterior Posterior arc 24 25 (0.923879 0.38268 1) arc 25 26 (0.38268 0.923879 1) arc 26 27 (-0.38268 0.923879 1) arc 27 28 (-0.923879 0.38268 1) arc 28 29 (-0.923879 -0.38268 1) arc 29 30 (-0.38268 -0.923879 1) arc 30 31 (0.38268 -0.923879 1) arc 31 24 (0.923879 -0.38268 1) ); boundary ( ParedesFrontalLateral { type wall; faces ( (0 1 8 9) (16 17 24 25) (1 2 9 10) (17 18 25 26) (2 3 10 11) (18 19 26 27) (3 4 11 12) (19 20 27 28) (4 5 12 13) (20 21 28 29) (5 6 13 14) (21 22 29 30) (6 7 14 15) (22 23 30 31) (7 0 15 8) (23 16 31 24) ); } Cilindro { type wall; faces ( //Externo ); } ); mergePatchPairs ( ); It runs ok with the bockMesh command, but when I try to use it with paraFoam, it inmmedeatly closes and throws an error. I don't really understand why. In the other hand, I want to specify the inner circles as an empty patches...¿how can I do it? and ¿How can I specify a type of flow for this faces? Thank you for your help Last edited by fisherman05; February 18, 2013 at 14:02. Reason: Code - Change after revision |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
[GAMBIT] Need help in modeling and meshing air flow over a tree | czi1127 | ANSYS Meshing & Geometry | 1 | December 19, 2012 04:43 |
Flow past 2 smooth circular cylinder | slip | FLUENT | 0 | July 8, 2010 19:45 |
flow resistance of cylinder in parallel flow | Ralf Schmidt | Main CFD Forum | 3 | May 11, 2009 03:26 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
