plzzz help::energy equation using power law method |
April 17, 2012, 10:32 |
maryam
Rep Power: 14 |
hello every body
I am writing fortran code for 3-D fluid flow in a rectangular duct. I have problem with descritising energy equation using pawer law method (finite volume). integrating viscous term is some how inpossible. one friend told me to take out that part out of integral like a constant number. is it right??????? and if it is right i have other problem descritising terms like d(u)/d(y). should i do it like what i do for momentom equation( i mean the formula used to find a(nb)) or the accsess is gained only through interpolation? thanks. sepideh |
April 17, 2012, 19:36 |
#2 | |
Arjun
Rep Power: 34 |
The temperature equations has viscous heating term = viscosity * shear rate^2 . Thats all. The viscosity is calculated based on what is currently available as best guess for temperature. Typically power law with temperature dependence would be of this form: viscosity = m * EXP(tc * (T - t0)) * shear rate ^ (n-1) Where T is temperature. PS: This is not an easy calculation to do. I did last week or two ago for our company and i can tell you it is very tricky business to put into practice. |
April 18, 2012, 02:09 |
maryam
Rep Power: 14 |
thanks arjun
but I have a problem understanding you. do you mean with integrating energy equation I will reach your last equation? what is tc and t0? i should mention that I am studying steady flow |
April 18, 2012, 04:32 |
#4 | |
Arjun
Rep Power: 34 |
There are no terms related to time in it. Tc and T0 are constant so you can use it for steady case too. In fact i also did steady calculation. |
April 20, 2012, 06:36 |
#5 | |
Rep Power: 16 |
Energy equation is a transport equation with a convective term , a diffusive term and sometime a source term. The power law scheme is used to discritize the convective term of the equation (one could use UDS scheme, CDS scheme etc....) The diffusive term are generally discritized using central second order finite difference. To me the both are not linked (power law scheme and diffusive term) Check Patankar' book or Versteek and Malalasekera book. Everything is perfectly explained in it. |
April 20, 2012, 09:05 |
#6 | |
Arjun
Rep Power: 34 |
O man, I completely mistook him. I thought he was asking about power law fluid with viscous heating in temperature equation. |
energy equation, finite volume method, pawer-law |
CFX non newtonian power law fluid | Mehmet SORGUN | CFX | 4 | October 13, 2013 11:25 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
about one seventh power law in CFX | Eric | CFX | 3 | January 10, 2007 08:16 |
1/7 power law | Eric | Main CFD Forum | 0 | December 28, 2006 00:48 |
Viscosity - power law | HOC | Main CFD Forum | 1 | January 15, 2003 16:17 |
