Reactive flow algorithm
Old   September 28, 2005, 19:16
Default Reactive flow algorithm
Arthur
Hi all, I want to set up a case were I have a chemical reaction network. I have a good fortran code that allows for any number of scalars and would like to use it for my case. Can anyone explain me what shall I do ( the algorithm) in order to implement my case or direct me to some available sources?
Thanks in advance
Old   October 5, 2005, 20:43
Default Re: Reactive flow algorithm
gerald
I am not sure what exactly you would like to do, but it sounds as if you would like to put chemical reactions atop of your existing CFD code. If this is indeed so, the easiest way to accomplish this is to use COSILAB_lib from Softpredict (use Google). This is a fleet of precompiled chemistry and combustion functions, available in Fortran, C and C++, that you can link in form of a dynamic link library(DLL) to your own code. This is straightforwardly done, but it is available only for the Windows OS.
Old   October 15, 2005, 11:52
nitesurfer
Thnx I will give it a try
nite
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
compressible flow algorithm ztdep Main CFD Forum 4 April 27, 2008 21:41
CFD of single-phase liquid reactive flow Ingo Meisel Main CFD Forum 1 September 17, 2005 07:42
mixing-sensitive reactive flow - subgrid scales Ingo Meisel Main CFD Forum 4 June 25, 2004 16:39
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
