Drag coefficient for 3D rectangular cylinder
Old   September 28, 2005, 10:52
Default Drag coefficient for 3D rectangular cylinder
karthik
hello
i'm using FLUENT to find Cd values for 3D rectangular body (parallelopiped)....i have got some results from fluent...i kept the frontal area same and increased the Length of the cylinder(length parallel to flow)....
frontal area : 3x3
length : 0.5m, 1, 2,3, 6,12, 18, 24
Cd values are first decreasing as the length increases and after 3m length, the values are increasing....i did for a range of Re....my fluid is water....
and i'm not able to give a logical explanation for the increase in Cd values as the length is increased..... please help me in this regard...if u know any journal,please give me the title.... any kind of help is highly appreciated... Thanks a lot in advance...
regards
karthik.S
Old   September 28, 2005, 13:38
Default Re: Drag coefficient for 3D rectangular cylinder
jasond
It's a little difficult to say offhand, especially without knowing what the Re range is (giving that would help). Here are a few things to look at: What is the boundary layer on the body doing as length increases, and what is happening to the pressure behind (and in front) of your body as the length increases? The force on the body should be made up of shear forces + pressure forces, so that is how I would start.
jason
Old   September 28, 2005, 14:46
karthik
hi jason
i'm modelling for turbulent flow...Re from 10^5 and above.....let me check the pressure behind the body... thanks for ur help and others if u have any idea..pls do post ur replies... thanks regards..
karthik
Old   September 29, 2005, 15:18
Mani
The dependence of the Cd on the length may indicate three-dimensional effects. Take a look at the solution to see if there is any variation in spanwise direction. There should be... What boundary conditions are you using on the side?
Another important question: What do you exactly mean by Cd? Are you running steady state, or are you running unsteady and taking the time-averaged Cd? You should do the latter, because at such high Reynolds number the flow is surely unsteady, and the steady state equations will not give you the correct drag.Not only is the flow unsteady, but you should also expect significant spanwise variations at high Re. Depending on the cylinder length, you may get different modes of vortex shedding, which may result in different time-averaged drag coefficients.
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 04:26
Drag Coefficient Verification around Cylinder MFerris CFX 44 May 11, 2015 19:27
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 06:08
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 11:50
